submersible or jet pump for 28 ft deep well?
   / submersible or jet pump for 28 ft deep well? #11
as it will be cheaper and easier to get 120 v out there. It'd be about 50 ft from the panel to the well.
If you get a 2 wire pump you will only need the 2 220v legs and a ground, so you can use the only cost difference will be in the breaker.
A 220v pump will pull less amps per leg, so you can use lighter wire.
As a random example, the recommended fuse sizes for a Flotech 1/2 hp submersible well pump are: 115v 35 amps. 230v 20 amps
You can also go 104 feet with 14 gauge wire and a 1/2hp 115v pump, but you can go 400 feet with the 230v version of the same pump and 14 gauge wire
Source (charts on pages 6-7): http://www.pumpvendor.com/media/flotec/pdf/Flotec_4_inch_2_and_3_wire_submersible_well_pumps.pdf
Aaron Z
   / submersible or jet pump for 28 ft deep well? #12
Aczlan,
The 220V 2 Wire 1/2 HP motor is 5-6 Amps, the 115 V 2 Wire 10-12 amps. A 15 Amp double breaker to support the 2 wire 220V will work fine, and the 115V 20 Amps would work but the suggested is 30 as you note due to the starting current.
I have a 1.5 HP on a 30 Amp breaker and the starting current spikes to 20-22 Amps then it runs at 9-10 amps.
Its better to go with the 220V especially if this will be used with a generator at any point in the future due to the balanced loads.
Carl
   / submersible or jet pump for 28 ft deep well? #13
Thanks guys. I'm now leaning towards going with a submersible pump. This way I won't have to worry about priming it.
I'll probably go with a 120 volt pump as it will be cheaper and easier to get 120 v out there. It'd be about 50 ft from the panel to the well.
If the well yields well enough and the water is okay. I plan to later hook it to the camper. I can't stand the city water around here for drinking. Too much Chlorine. Sometimes you can even smell it.
So when I do that I'll build a well house to house the tank and piping.
Chad
I also vote for submersible. They now have "constant pressure" pump controllers. I don't know how they work but if they do not need a pressure tank that is what I wouild be using. Cuts one more maintenance item out of the mix.
If you go for a 'top of the well pump' at your measurements you maybe could get away with a simple shallow well pump (not a 'jet'). A shallow well will suck from about 26' at sea level - decreases with altitude. Of coruse that runs you back to the 'priming/frost protection' problems.
Harry k
   / submersible or jet pump for 28 ft deep well? #14
One other think to add. If you go 220V, you can use a three wire pump with a box. This box contains relays and capacitors that are inside the motor of a 120v two wire. If you have a failure in one of these parts, you can replace it. If that part fails in the 120v motor, you have to pull the pump and replace the whole motor. Just a few more facts to put in the mix.
John Deere 853 20ft Corn Head (A56436)
John Deere 853...
2003 Freightiner FLD120 (A56436)
2003 Freightiner...
207271 (A52708)
207271 (A52708)
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
