Sudden smoke problem with 2520
   / Sudden smoke problem with 2520 #1
GordNovo
near
Hello all, encountered a sudden problem today with my 2520..and it's got me a little nervous that it could be a serious issue. Was running the machine for about 2 hrs with the FEL and box blade, moving some stone and gravel, so the engine was quite warm. No signs of engine overheating via the dash light though. While I was off the machine adjusting the sway on the box blade I looked up and suddenly noticed a large amount of smoke pouring from the exhaust. Engine was at approx 2200 rpm at the time. I quickly turned it off, thinking I blew a gasket maybe. The smoke smelled very oily, unlike the smell you usually get with a blown gasket. After a couple of mins i tried to restart but it seemed to be seized up.. the engine cranked a 1/2 turn, then stopped completely. it made very 'crunchy' kind of sounds when it tried to turn over. It has never done that before!! I tried to start again a few more times, but couldn't get it the engine to turn over... it just kept doing the same thing.. 1/2 crank, then nothing, no motion. After a few more mins, I tried again, and finally got the engine to turn over and finally it fired up but again it smoked like a bugger! I noticed the smoke is grey in color and is fairly faint when idling, but if I increase the RPM, the smoke is very evident. Plus the engine is definitely misfiring, both at idle and at faster speeds.
I checked the oil and it seemed to be over the full mark, suggesting a blown gasket, but the smoke doesn't smell like it though.
I immediately loaded it on the trailer and dropped it at the dealer this evening, hoping they'll have a look at it soon for me. it's got 260 hrs on it. First oil change at 50 hrs in the fall last year, and 2nd oil change this spring at 160.
i've read similar posts suggesting a bad injector, or maybe fuel or possibly still a gasket. I think I can rule out fuel since it ran nicely for 2 hrs before hand.
The thing that's got me perplexed is the seized up symptom when I tried starting it when the problem first arose.
GN
   / Sudden smoke problem with 2520 #2
GN
Man, that sucks. Let us know what they find.
D.
   / Sudden smoke problem with 2520 #3
The "seized up" symptom could have been caused by liquid in a cylinder preventing one of the pistons from completing a compression stroke. For a high-compression engine, it wouldn't take much liquid to stop it from turning over.
When you didn't crank the engine for several minutes, maybe coolant in the cylinder leaked past the rings and into the crankcase so you were then able to crank the engine.
As ddivinia requests, please let us know what the outcome is.
   / Sudden smoke problem with 2520 #4
Whoa.. water or coolant leaking into a cylinder is very bad! Water doesn't compress and if there's enough water in the cylinder and the engine fires up --- there goes your piston or rod into chunks!!
Sure hope it's not that...
AKfish
   / Sudden smoke problem with 2520 #5
Bad news GN, however you are still under warranty right? 24 months 2000hours. I'd be glad this happened now, not 30 months into ownership:eek: Maybe you can get a loaner?
I agree with Ted, it sounds like a hydro-lock situation. You did right getting it to the dealer right away. AK is right about the dangers of liquid in a cylinder, but it sounds like this one made it. I've have the doubtful pleasure of telling more than one nice person that their engine has suffered fatal damage from hydro-lock. Very few were within warranty protection.:(
Good luck..keep us informed..........
   / Sudden smoke problem with 2520 #6
That SUCKS big time:mad:
   / Sudden smoke problem with 2520 #7
Sounds like a blow head gasket. Could you tell what was in the oil? Water in the oil?
Maybe it is a bad fuel injector - leaking lots of fuel or something. It is was water, wouldn't the smoke be white?
D.
   / Sudden smoke problem with 2520 #8
D.
I will put my money on a stuck open injector. That would pour smoke and hydrolock the cyl. when shut down.
They're looking at it today and will let me know.
Thanks fellas.
GN
   / Sudden smoke problem with 2520 #10
Not getting my money, I agree.
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
1992 BOBCAT 743 SKID STEER (A52705)
1992 BOBCAT 743...
SKLP Windmill Shooting Target (A53316)
SKLP Windmill...
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
ROADTEC RP-190E-3043 ASPHALT PAVER (A52705)
ROADTEC...
