Suggestions and do I need 4wd?
   / Suggestions and do I need 4wd?
I’d wait till spring and grass is growing. Buy the X590 with HDAP tires. Without pictures of your slope hard to say, but if the craftsman did it the X590 will laugh at it. The 590 is much wider (more stable on hills) bigger tires and the locker. Personally I have a neighbor that had a hill he couldn’t do with his husky, refused to climb the hill, ran away going downhill, and slide like crazy trying to cut it sideways. So I said I’ll give it a try- with my X590 I could go up the hill, down the hill , across hill didn’t matter. Needless to say he now owns a john Deere. Anyhow I say wait till spring and grass is growing, buy the X590 – 95% chance it works fine, but if it doesn’t use John Deere promise and go with 4WD x7xx series tractor (a lot more money)
Sensible advice. Thank you
   / Suggestions and do I need 4wd? #32
Just a passing thought. Why do folks insist on mowing areas that may present potential dangers. There are areas in and around my house and outbuildings that are steep. I recognize this and simply don't mow these areas. I CERTAINLY don't need added dangers out here - I'm all by myself and have plenty otherwise.
If that steep area doesn't get mowed - so be it.
   / Suggestions and do I need 4wd? #33
I have to mow mine. No choice. I let it grow for a few years and it got so out of control with blackberries, honeysuckle and locust saplings it was a real bear to clean up again. Several years later, it still isn't right.
I could cut back to mowing it just a few times a year with the field and brush mower, but I opted to keep at it until I get the wild growth back under control. With the SCUT now, I may be able to do it every three or four weeks instead of every 7-10 days, but I'll have to see how that goes.
   / Suggestions and do I need 4wd? #34
Diggin it - that's a totally different situation than some grassy knoll left uncut. My tender locust bushes get proper care with my big 'ol Stihl 350 weed whacker every now and then. And on the far side of Coeur 'd Allene Lk - I've seen what blackberries, left unchecked, can do. Dare not fall when out picking them.
In my case fair question.
In one of my posts I mentioned the large stable Kubota and using the brush hog in areas we don’t mow.
That area is actually the grassy knoll as you describe. No mower belongs on it. Done only once a year to control the mess.
My flip the tractor hill is actually a long narrow path near the house I need to keep clear. Mowing downhill with the garden tractor that does not slip (the Craftsman) works out as the safe choice. The incidents in the past came when mowing that uphill and loosing traction due to stubborn poor choices (maybe wet, maybe blocked). The resultant backwards slide never ended well. (I finally stopped trying before hurting myself).
(In the same place I did try a walk behind wheeled weed wacker and a heavy walk behind brush hog. We wore out the underpowered weed wacker and the brush hog (while a true beast) was too heavy to control on the slope.)
So yes an option is to not mow a dangerous area at all, nor with the wrong equipment, nor with the wrong strategy.
(Honestly I do love to watch the highway mowers in places where the operators could probably stand up straight on the sides of their cabs. Crazy stuff but yes unsafe on our relatively tiny equipment.)
   / Suggestions and do I need 4wd? #36
DavidVT - I DON'T want you to think I'm being, in any way, critical. There is just no need to get hurt while mowing. A few year back I helped get a fellow unstuck with my ATV. The ATV came over backwards and landed on me. It hurt like the blue blazes. And I WAS pulling from the ATV drawbar. The ATV rear tires got max traction and the unit simply rared up and came back over on me. Rather than pulling forward. Every time you use a piece of equipment - you are rolling the dice. Play it safe - beat the house.
   / Suggestions and do I need 4wd? #37
DavidVT after looking at your post I looked up new simplicity line up and I guess your right no diesel or water cooled . When briggs bought simplicity lots of things changed . I have the water cooled kawaski in mine . Same engine as jd uses . They use to offer a diesel but no more I guess. Furthermore it don't seem like there is optional engines.31 carb for 2 wd and 33 efi for 4wd. I wouldn't comment on new briggs engines . But the old ones weren't up to the jap engines.:confused3::drink:
Oh, my response was written with a smile. No offense taken whatsoever! This is a guy who years ago was t-boned in my brand new tractor by a speeding car on slick icy roads at a blind knoll. The tractor split and was totaled. I was tossed out of view of the driver who thought he rolled over me. I know we take a risk every time we climb onto the equipment.
   / Suggestions and do I need 4wd? #39
When I got my x500 the dealer told me to leave the anti-scalping wheels close to all the way up. He said that most people left them so low they were in contact almost all the time and wore out quickly. I tried that once and it was a mistake. By the time the wheel touched it was too late and the blade had already cut the grass down to dirt. Now I have them adjusted for my lawn (I think either one or two holes up from almost touching on flat grass) and they often touch the ground but scalping is a thing of the past.
As for a 2wd mower goes, I have never had any luck trying to back up a hill. If you have a spot where you need to then 4wd is going to be your best option. There's just not enough weight on the rear tires. Even going down steep hills I will back down if in doubt. I also use the diff lock but rarely need to use the brake. The hydro transmission does a very good job regulating the speed when going down all but the steepest of hills.
   / Suggestions and do I need 4wd? #40
As the book says... adjust the deck with tires aired to correct psi, then on a flat surface after raising deck wheels and setting cutting height (i.e. 2-1/2"), adjust right and left turnbuckles to blade tips at that same 2-1/2", adjust forward bail so forward tip of center blade is 1/8 to 1/4" lower than rear tip of center blade, then lower the deck wheels to 1/4 - 1/2" above ground level.
Should be good to go.. always works for me..
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
Towable Sprayer (A59228)
Towable Sprayer...
2017 Rogator RG1300B Dry Fertilizer Applicator (A56438)
2017 Rogator...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
