Suggestions for 2 acre tractor
   / Suggestions for 2 acre tractor #31
Hi all. New member here. I am in need of a tractor for 2 acres of land and would like suggestions on the size of tractor I will want. I will need to move snow from my driveway and sidewalk, haul dirt/gravel/firewood/rocks, clear forest, eventually till, and maybe some digging. The land is mostly forest that I will be clearing for garden space. There is very little grass but I have a push mower to take care of that. I have a standard garage space to store the tractor.
I've mostly been looking at Kubotas since there is a dealer close to me. The B series I've been researching. There are also close JD dealers. 20 miles away there are more various dealers.
As a side question, will moving snow off a sidewalk that is maybe 3 ft wide ruin the grass on the edges if I use a tractor?
I would recommend larger equipment for the initial work, something like a Kubota L45 tlb or M59tlb. Problem is that is way to big to maintain 2 acres. I really think you need to separate the initial work from the long term maintenance work. While you can make this a DIY project and buy the larger tractors and equipment to do this it would be at a high cost. I maintain a lot of 2 acres parcels with a garden tractor, but would not recommend less than a 50 hp tractor for the initial work.
That said I would consider rent or hire a contractor for the heavy work and buy a small tractor that fits your maintenance needs.
   / Suggestions for 2 acre tractor #32
Since you've settled on a small B let me recommend a B7610 :) Big enough to do a lot, small enough to get thru a 5' gate. Or a 2320 :)
I've been able to do a fair bit with my 7610 and look forward to doing a lot more.
   / Suggestions for 2 acre tractor #33
I looked very seriously at the Kubota B Series and thought maybe the B2920 would be a good bet. I just decided I couldn't live with the quarter inching valve 3PH, turnbuckle stabilizers, no extendable lower links, live PTO etc. I prefer the B2630/3030/B2650 etc. They are however significantly more expensive. As an alternative, my brother recently bought a Kioti CK27.
   / Suggestions for 2 acre tractor #34
I went through a similar thing. I only wanted one tractor to do all my work. One engine to maintain(maintaining the big trucks consumes my life, don't need more headaches.) So it needs to mow 2 acres and I also do my own firewood in 5+ acres of bush.
I bought a B2620 (more loader capacity than the 2320 at just about the same footprint.) Kubota wasn't on my initial want list, but now that I bought one, I love it.
The problem we share is for our logs and my snow removal......we really need a bigger tractor. But anything bigger than the B would be overkill for 2 acres of lawn. (Unless you are the type that buys an F-450 diesel and only drive to get groceries, which many people seem to do?)
So you have to make a compromise or buy a big tractor and a dedicated mower.
In my case, I have discovered I can easily lift and carry 9 foot long, 19" diameter maple logs with my B, to my surprise.
How might the B2320 handle snow? I have short (100') driveway and typically ~12" snowfalls. Sometimes get a big snowfall of 24". And can the loader on a B2320 handle that much snow for the most part? I don't have much need to move mountains of snow.
   / Suggestions for 2 acre tractor #36
I categorize an FEL right next to an aluminum shovel for clearing a driveway. They are good for piling it high. But in your case, it'll work fine if it's what you've got. 100' driveway isn't much snow to move. You'll have fun doing it!!! :)
   / Suggestions for 2 acre tractor #37
Even though my B7610 has never been north of the Mason Dixon line we have had about 4 major major snowfalls since 2009. My biggest problem was getting the tractor shoveled out. As soon as I got room to move it handled about 20" with ease. Just with the FEL. A blade would have even been easier. I did have chains on.
   / Suggestions for 2 acre tractor #38
You will be fine with the fel with only 100 feet....as long as you don't have a big turnaround area. Otherwise it will take time chasing the windrows.
No problem with power or traction though.
   / Suggestions for 2 acre tractor #39
My driveway is close to 800' long. Snow blower that hangs off the front of the machine is how I have done it the past two years. Not sure why I lived there all that time without one.
2006 Caterpillar 315C L Hydraulic Excavator (A56857)
2006 Caterpillar...
2015 Toro Reelmaster 5510D Fairway Commercial Reel Mower (A56857)
2015 Toro...
2014 Dodge Ram 4500 Versalift Bucket Truck (A55973)
2014 Dodge Ram...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
Tank Only (A59076)
Tank Only (A59076)
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
