SUPER DUTY CUTTER??
/ SUPER DUTY CUTTER?? #1
Giles
Florence Alabama
2009 Kubota B2320---Wheelhorse lawn mower--- Case 480D Backhoe
Just for a good smile or even a laugh--check this out:thumbsup:
Wonder what shipping would cost???
dallas.craigslist.org/sdf/grd/1917302755.html
/ SUPER DUTY CUTTER?? #2
No deck, huh? I sure wouldn't want to be close when that bad boy is engaged! :shocked:
Joe
/ SUPER DUTY CUTTER?? #3
faster you go the farther it throws, so drive fast and clear your trail.:thumbsup:
/ SUPER DUTY CUTTER?? #4
my math puts the blade speed between 150-200rpm @4mph
most brush hog gear boxes are ~1.5:1 speed up
so 540*1.5= 810rpm
me thinks it ant going to cut worth a poo!
/ SUPER DUTY CUTTER?? #5
Used to see those all over North East and Central Texas back before batwings became so common. They would pull them several wide to mow pastures. They cut pretty good, just were a little dangerous if you hit anything while cutting.
/ SUPER DUTY CUTTER?? #6
Just need a seat on top of the differential to make it the perfect thrill ride. :cool:
/ SUPER DUTY CUTTER?? #8
so 540*1.5= 810rpm
I agree. I figured based on a 40" tire @ 4MPH the tire itself would only rotate at about 34 rpm. And some of those 2-speed rears had close to a 9:1 ratio, that still only puts it @ 300rpm blade speed. That definatally aint going to cut very well. Not to mention when he gets into heavier stuff, I see the grass just wrapping up and casuing the tires to slip.
And even 4 MPH with a 800rpm blade from a REAL bushog is sometimes a bit much in heavy stuff.
My guess is that is why it is forsale. He built it , found out it didn't work, and now wants to sell it and take the money for a real cutter. I'd love to see a video though.
2019 22ft Forest River Salem Cruise Lite T/A Trailer, (A61574)
2019 22ft Forest...
2010 Dodge Charger Sedan (A61574)
2010 Dodge Charger...
2014 Wanco FD-304 Folding Solar Towable Arrow Board (A61572)
2014 Wanco FD-304...
(2) 60 GAL POLY SIDE MOUNT TANKS (A63291)
(2) 60 GAL POLY...
Caterpillar Traxcavator service manuals (A63117)
Caterpillar...
E-Z DUMPER T/A DUMP TRAILER (A63291)
E-Z DUMPER T/A...
