Sweeper machine Broom
/ Sweeper machine Broom #1
tejasp56
Vadodara
Mahindra
Can any body tell me how to calculate torque to rotate sweeper machine broom?
Broom Dia is - 0.6 m
Length - 2 m
Weight - 150 Kg
Rotating RPM - 150
/ Sweeper machine Broom #2
Everything you have is meaning less until you to have decided the
engine size/Horse Power and determine whether you will be using
chain drive and sprockets or V belts and pulleys before you go
any further as the sprocket size length between the center lines of
the shafts or the V belt pulleys and the pulley diameters if you pursue
a V-belt drive.
a V-belt drive.
I want to mount hydraulic motor on other side of broom.
/ Sweeper machine Broom #4
:welcome:
To TBN Tejasp. I take it that you are in Gujarat, India?
/ Sweeper machine Broom #6
I don't know how to calculate it, but the walk-behind 3' wide units have around ten hp. Double that for 2 meters? Your profile shows you are a manufacturer, so you would want more accuracy than I can give you. Gujarat was Gandhi's birthplace, I think?
Jim
/ Sweeper machine Broom #7
Length - 2 m
Weight - 150 Kg
Rotating RPM - 150
First you have to figure out how hard the brush will be to turn in use. This will be controlled by downforce and type of bristles, AND what is being swept. -- You could set full weight down and measure it directly with a torque wrench. ... A value of ~ 300 ft-lb seems about right from my experience. If broom gearing provides a 3 to 1 speed reduction your hyd drive motor would need to be capable of 100 ftlb torque.
larry
2010 Ford Crown Victoria Sedan (A61574)
2010 Ford Crown...
1100 GAL FLAT BOTTOM POLY STORAGE TANK (A63745)
1100 GAL FLAT...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
(4) 23.1-26 R1 Tires & 12 Lug Wheels (A62183)
(4) 23.1-26 R1...
KUBOTA MI08S TRACTOR (A63276)
KUBOTA MI08S...
2017 CATERPILLAR 980M WHEEL LOADER (A62129)
2017 CATERPILLAR...
