T1-11 VS. smart siding?
   / T1-11 VS. smart siding? #22
Nasty, my post wasn't meant for you, I just clicked reply after the last message. It was meant for the original poster. This is the steel siding that I used
   / T1-11 VS. smart siding? #23
Do you have any more pictures of your barn with that vertical siding? I think that may be what I'm loking for. I went to the manufacturer web page but they were lacking in useful photos of installations. I am curious how you dealt with windows with the vertical nature of the siding.
Cliff
   / T1-11 VS. smart siding? #24
Inspector507, Thanks my bad, I'm still learning how to do somethings... /forums/images/graemlins/smile.gif
Molerj, Ok no problem,Your post was a little vague to me anyhow, I guess it was because you replied off my post /forums/images/graemlins/laugh.gif
   / T1-11 VS. smart siding? #25
Cliff_Johns, It's under projects, bubbas basic barn,around 3/29/04 ,I'll try to link it barn thread Only two pics with siding done. /forums/images/graemlins/frown.gif With windows you just use j channel like regular siding, instead of going up you go left or right which ever way you start,depends if your right handed or left handed it can work to your advantage... /forums/images/graemlins/cool.gif
   / T1-11 VS. smart siding? #26
</font><font color="blue" class="small">( Cliff_Johns, It's under projects, bubbas basic barn,around 3/29/04 )</font>
Thanks very much. Nice thread. great pictures. very helpful.
Cliff
   / T1-11 VS. smart siding? #28
Yes, put the siding up first, then putting the 1 1/2" lip over the siding will work fine the way you described. It will cover your cut edge up and keep water from getting inside the wall.
   / T1-11 VS. smart siding? #30
Mopower440, If you decide to use the vinyl siding you will need to do your trim work (j-channel around windows doors & eves,outside corners & inside corners if you have any inside corners that is) before you start your siding panels, so the cut ends of the panels are tucked in the j-channel (unseen)
Also a good tip if I can explain ,When cutting the j-channel above doors & windows cut the j-channel about 2" longer than it needs to be,then trim with snips the face of the j-channel on the ends the extra 1"on each side back to be even with the window and also do that to the side attached to the barn leaving a 3/4" tab that you can bend down into the vertical j-channel going up the side which helps in tighter fitting the trim and also helps in sealing the weather(water) out! /forums/images/graemlins/shocked.gif
2017 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2017 CATERPILLAR...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
71058 (A49346)
71058 (A49346)
Crash Mobile S/A Trailer (A50324)
Crash Mobile S/A...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
