t1510 New Holland cab build
   / t1510 New Holland cab build
   / t1510 New Holland cab build #14
Very nice job. Looks very similar to a used cab I purchased from the local driving range; suicide doors and all. It was used to pick up golf balls at the range and had expanded metal welded to the cab frame.I bought the cab - more like a cage, for $50.00. After cutting away HUNDREDS of spot welds to remove the expanded metal, I was able to fit it on my B1750. I skinned it with orange poly on the lower half and clear on the upper. No heat, but all I need is something to shelter me from the wind. Worked well last winter.
   / t1510 New Holland cab build #15
Your cab is looking great and I like the "X" deformation in the roof to cut down on vibration and add some stiffness.
OK, what is that beast of a machine behind your cab in the second picture? It almost looks like an asphalt rotomiller.
The machine behind the cab is a gravel conveyor , we were doing an overhaul of a client's gravel crushing outfit in the shop
   / t1510 New Holland cab build #18
Thanks for the pictures
   / t1510 New Holland cab build #19
Looks like your cab is coming along well. I was actually on kijiji the other nite and seen your add for your other cab. But i think sooner or later i will just take the time and build a cab. More time than anything really.
   / t1510 New Holland cab build #20
Nice job on the cab, Surplus center has wiper motors, I think there $29, these are a must when snowblowing
John Deere 5055E (A53317)
John Deere 5055E...
2002 MACK CHU613 BOBTAIL VAC TRUCK (INOPERABLE) (A55745)
2002 MACK CHU613...
TOOTH ATTACHMENT FOR MINI-EX (A55745)
TOOTH ATTACHMENT...
2009 Pierce 105ft. Quint Ladder T/A Fire Truck (A53422)
2009 Pierce 105ft...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2022 John Deere 5065E MFWD Tractor (A53485)
2022 John Deere...
