T273 Transmission Toast?
   / T273 Transmission Toast?
So, quick update. New drive-shaft arrived last Friday and it's a night and day improvement in engineering. It telescopes and has a U-joint on each end. No O-rings, just a single G5 bolt on each end that you tighten down.
It took me no more than 10 min to install the new shaft through the hole I had cut in the floor to remove the broken shaft. It can be a bit tricky to line up the splines on the transmission and engine shaft, but a few turns on the key to hit the starter took care of that. Tightening the bolts is also tricky as there is very little clearance to get your hands and a wrench in the hole.
Mowed for 4 hours over the weekend without issue. Even sounds quieter. If you have an older model TYM (mine is 2008) and you haven't replaced the drive-shaft due it! Better to catch it early before you strip the transmission shaft. I got lucky :).
Thanks as always to the TBN community for sharing their ideas and insights! Mission success.
   / T273 Transmission Toast? #22
I needed a Brake switch assembly, called Jordan Sales and my replacement part is being shipped today!!
Great service and fine people to deal with!! Very happy to have a source for needed items that aren't easily found/swapped locally.
I also give a "Shout Out" to Jordan's' and to any TYM owners needing a parts source. Greg
Miller Welder (A47809)
2018 Nissan Frontier Ext. Cab Pickup Truck (A46684)
2018 Nissan...
2011 FORD EXPEDITION (A47001)
2011 FORD...
Allterrain 10' Storage Container (A47809)
Allterrain 10'...
2014 PETERBILT 367 (A47001)
2014 PETERBILT 367...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A45336)
2018 Skyjack...
