Tandem Disc Harrows
   / Tandem Disc Harrows
Eastinlet said:
Good gosh! Even if I could afford it, my little tractor would sit and spin trying to pull 1800 pounds of disk in soft sandy loam.
It works out at 112# per disc. I don't think my 47hp would pull it.
   / Tandem Disc Harrows #42
Farmwithjunk said:
With any disc, probably the most telltale "spec" is lbs per disc. Weight equals mass. Mass USUALLY equals strength. It ALWAYS equals soil penetration. When considering different models, compare lbs per blade.
A lightweight disc can have weight added, but consider that lightweight frame may or may not respond well to adding substancial amounts of weight. Some fold like a tent when put to the test.
Notched blades cut better, but will tend to bend (or break) easier than plain. More an issue in rocky soils.
I personally prefer a disc with scrapers. That's more important in plowed ground (or muddy conditions)
If the info is available, pay attention to gauge of disc blades. Some mighty thin ones on the market. They bend easier and wear out quicker.
You'll find 3-point disc's with either sealed bearings or cast "boxings". Both are acceptable. Sealed bearings are good if maintained. Boxings will remain servicable long after wear becomes evident. For a disc that'll see ocassional use, I personally would prefer the boxings. The deal with wear/dirt/water/rust/abuse in a much more forgiving manner.
The disc in your picture appears to be a decent model. From appearances, the gang frame (black box tubing) appears hollow. Some are solid bar stock. Besides the obvious strength issue, solid bar has more weight.
Farmwithjunk,
How would you maintain a sealed bearing?
   / Tandem Disc Harrows #43
Grease...often. All the "sealed bearings" I've seen on a disc were sealed (in an attempt) to keep dirt from getting IN past the seal, but allowing excess grease to push OUT past the seal. New grease should displace any dirt or moisture that gets past the seal. Considering that a disc operates in an environment of flying dirt, even GOOD seals don't last forever.
   / Tandem Disc Harrows #44
Soundguy said:
Speaking of discs and grey iron bearings.. who remembers wood bearing halves?
soundguy
I have and use one regularly. It's an International Harvester Model 7A pull type 6.5' width. I pull it behind my Kubota L3830. I don't spare the grease on the boxings and grease them after about every four hours of use. My father bought it new in 1948 to pull behind a John Deere Model L tractor which struggled to pull it. In 1950 he traded the JD for a new Avery R tractor which is in my shop. It still cranks and runs.:D
Bill
   / Tandem Disc Harrows #45
Barneyhunts said:
Farmwithjunk,
Thanks.
Some of the confusion about "sealed" disk bearings is that at one time some of them (JD disks?) were not re-greaseable, ie.they had no zerk fittings. If the seal were perfect and able to remain so the bearing would last a long time before needing replacement. But as Farmswithjunk says, the disking environment wasn't the best for these seals so I think the non-regreaseable ones fell out of favor.
   / Tandem Disc Harrows #46
Farmwithjunk said:
I've got about 50% of a 6' Ford disc laying in the scrap pile that has wooded bearings. They held up better than the frame. I dragged it here a few years ago when we cleaned out my uncles barn. It spent the better part of 10 years with a bunch of ammonium nitrate bags piled on top of it. Talk about rust.
Mines been reworked and worked on heavilly.. plenty by me ( reweld frame, and replace axles on one side and discs ) and befroe me i's obvious it was welded on and had bearing work.
If you ever make it out to your scrap pile could you snap a pic, and let me know the id number ont he tin tag, if yours is still legible.
I really should restore mine.. but last time i used it ( 4ys ago ), it was again ready for bearings on the other side, plus more welding. I had a bunch of old ford suitcase weights and concrete blocks chained on it for weight.. I've since scavenged the weights off for my 5000.. I have a feeling it won't get refurbed.. probably cost more to get parts than to grab a used one in better condition..
soundguy
   / Tandem Disc Harrows #47
Really... I fthe disc is only 1800#.. that means the 3pt on a class 2 tractor should have no problem lifting it.. if you can lift it.. then you can control depth of cut.. and with that.. you should be able to pull it pretty good... My 8n pulls a disc that weighed 800# or a tad more just fine.. and it's 20hp shy of your machine.. and alot less lift capacity of modern/larger tractors.. etc
I'm pretty sure my ex-NH1920 would lift 1800# on the 3pt.. and it was a 32hp machine..
soundguy
   / Tandem Disc Harrows #48
soundguy
I'm planning on swapping my scrap pile for a stack of dollar bills come springtime :eek: When I drag that old disc out, I'll check for an ID tag. Highly unlikely it's still legible though. We're talking SEVERE rust here.
Implements are worse than old tractors when it comes to investment required to make new again vs. real world value. Generally, it's easier and cheaper to find another that's intact than to buy all sorts of hard-to-find parts. Last year about this time, when I re-did the #66 Massey plow, I easily spent $1000 by the time I found the plow, got it here, bought all new wear parts, and put a "show car" paint job on it. I've got a great looking $400 plow now......
I just bought a Massey Ferguson #39 2-row corn planter off of EBAY. I paid more than I should have, but it's virtually "like new". I could have bought several "fix-er-uppers" for less money, and then spent a small fortune on parts. Going after it saturday!
   / Tandem Disc Harrows #49
soundguy
I guess you used it a lot of hours/acres. Of course disc blades will wear out especially if not of best quality or thin gauge, but if you're bending up the frame and axles you're probably piling too much weight on it. That will wreck the whole disk eventually.
   / Tandem Disc Harrows #50
I just bought a Massey Ferguson #39 2-row corn planter off of EBAY. I paid more than I should have, but it's virtually "like new". I could have bought several "fix-er-uppers" for less money, and then spent a small fortune on parts. Going after it saturday![/QUOTE]
Farmwithjunk,
The sealed bearings on my disc don't have grease fittings, do you recommend using a needle type tool to grease under (in back of) the seals?
Good luck with the MF #39 planter. I bought one last fall and you told me where I could buy plates for it. You're a good resource! I'm looking forward to using my planter this spring.
2006 X-L SPECIALIZED 40TON RGN (A50854)
2006 X-L...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
2023 John Deere 8R410 MFWD Tractor (A51039)
2023 John Deere...
2012 Chevrolet Traverse SUV (A50324)
2012 Chevrolet...
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
71069 (A49346)
71069 (A49346)
