Task Master 425A stopped running
   / Task Master 425A stopped running #32
I use 15W40 engine oil in mine and change it every 100 hours.
I change the engine oil every 50 hours.
Chris
   / Task Master 425A stopped running #33
Hi, I have the same problem with a Siromer 204 with a TY290X engine but this one will not start if stopped. Bleeding and generally messing around gets it going but if you pull the stop too hard it won't start again. Do you thing this is a sticky rack problem?
   / Task Master 425A stopped running #34
Sounds like it might be, alright. Have you flushed the governor housing with diesel and then put in new oil?
   / Task Master 425A stopped running #35
also check the stop linkage for sticking/binding
//greg//
   / Task Master 425A stopped running #36
It was the stop rod stuck across, the clearance to the housing is quite tight. Flushed, refilled bled and running!!
2019 John Deere XUV560E Utility Cart (A53421)
2019 John Deere...
Test Button (A47477)
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A53473)
Greenworks...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2017 HYDREMA 912HM ARTICULATED DUMP TRUCK (A52706)
2017 HYDREMA 912HM...
