TC 55 Steering
   / TC 55 Steering #51
For hydraulic noise, NH F200A will help some; it follows the same international specs as 5W20.
As far as the steering problem goes, the only thing that will work (without making an engineering change) is to add more weight behind the rear axle, a la ballasting box. Since the center of mass of the loader and load is fairly far in front of the front axle, it will take quite a bit of weight behind the tractor to counter the moment created by the loader. Note that adding wheel weights or liquid ballast will not help with the steering issue, because it does not remove weight from the front axle. Rear axle ballasting only acts to maintain sufficient traction with the rear tires when using front mounted implements.
It definitely does not help, correct me if I misread, that you have turf tires, which have a fairly large footprint. These type of tires have enough contact surface to require quite a bit more force to steer.
It is important to keep in mind that a 'properly' ballasted FWD tractor should carry about 40 percent of the tractor weight on the front axle.
I'm also not convinced that 'adding a second cylinder' or 'increasing the diameter of the one cylinder' is the proper solution. The simple fact of the matter is that the weight on the front axle of the tractor is cutting down on the natural FWD lead of the front driveline over the rear. This will lead to premature driveline fatigue and/or failure.
Remove the rear axle ballasting a put a lot of weight at the three point.
   / TC 55 Steering
13n0BrdngIrn please read the whole post no turf tires and more ballast then the unit weight
thanks for the input
   / TC 55 Steering #53
I am still thinking it has either to be a leaky hydraulic cylinder or the the relieve valve has an incorrect setting. Mine bogged up twice, only for a couple of seconds until the wheels started to roll again and that was it. Couldn't make her do it again with something in the bucket. But: I'll be using her a lot in the spring with forks on the quick latch and then we will see what happens, if it happens. The noise out of the hydraulic pump went away. I found out that I was 6.5 L short on oil. Now I only have a little noise for 5 seconds when it is realy cold outside coming out of the pump @ 35hrs. /forums/images/graemlins/cool.gif
Cheers!
   / TC 55 Steering
STILL SAME /forums/images/graemlins/frown.gif
   / TC 55 Steering #56
With only 25 hours on the meter will NH and your dealer let you trade up to a SS axle? We have never had a minutes worth of problems with steering on the 40D in the 2 years that we have used it. Sounds like a good fix for a bad problem.
   / TC 55 Steering #57
Supersteer is not available for the TC55.
   / TC 55 Steering #58
That is very unfortunate. /forums/images/graemlins/frown.gif
   / TC 55 Steering #60
How were those rattle SNACKS??????
CFG Industry H12R Mini Excavator (A57149)
CFG Industry H12R...
2338 (A58376)
2338 (A58376)
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
EZ-GO Freedom RXV Electric Golf Cart (A57149)
EZ-GO Freedom RXV...
LOT: Assorted Hammers (A59076)
LOT: Assorted...
1607 (A58375)
1607 (A58375)
