TC 55 Steering
   / TC 55 Steering #32
I don't know if this has been asked before or not - does your TC55 have a locking front differential? I notice that, when my front diff is locked, steering can be a bear. At one point I thought something was wrong, but then it dawned on me that the diff was locked and I was trying to steer when not moving very fast - a sure recipe for difficult steering.
   / TC 55 Steering
Definitely not the locking front differential thanks for the idea
   / TC 55 Steering
still no change just keeping it up top thanks
   / TC 55 Steering
My experience with New Holland Corp goes to prove a point, if you have a problem you need to be an hyper jerk and pound them relentlessly as taking the passive, easy going route has just gone nowhere (a sad statement itself).
** found this Iam Not Alone **
   / TC 55 Steering #36
This disturbs me a bit, I have always been looking at the Kubota 5030 hstc to replace the International 584 4wd we use. Recently a TN75D showed up for a good price and was considering it. I have been reading about a lot of small design flaws/manufacturing flaws that seem to be showing up in the NH's.
Our international has a problem in that the diff/hydraulic fluids have to be way over filled or the pump sucks air in uneven terrain. This is a problem working in the woods! The steering seizes and won't work until you get level again, a pain when you are stuck in a rut or whatnot.
   / TC 55 Steering #37
I just took posession of a new TC55DA with 18LA and loaded wheels. /forums/images/graemlins/grin.gif Read this thread and moved a pile of dirt and had no problems there. Then I put a big rock into the bucked (needed 4WD as the rear tires strated spinning) and shure enough I lost the power steering. /forums/images/graemlins/confused.gif What a bugger to turn! I lowered the loader with the rock still in it, jigged it around and I had the power steering back. /forums/images/graemlins/wink.gif I guess I have to play around a little more and see what happens.
   / TC 55 Steering #38
Diselmonk,
Your comments are similar to my experiences. I now have over 45 hours of FEL use on my tractor. I have moved over 6000 board feet of lumber. From the fall location of 12' long 36" diameter logs to stacks of boards being loaded onto my trailer.
Only once in a while do I start to loose steering. But with a jiggle it usually comes back. I have picked the rearend of the tractor off the ground with so much weight and with the rearend properly weighted I have hit logs that I can only move a few inches off the ground by just curkling the bucket.
I dont know the problem, but whatever it is , the problem is hidden in the tc55 tractors it just is magnified in our friend noeclark. If I had to guess I would say the hydrualic pump is straining to keep up the presure in the front end and there is a stuuck vavle. The jiggle must help lossen it... I have no real understanding of these tractors work though. One really gets lazy in the mechanicing world when ones brother has been a professional mechanic for 30 yrs and can replace your starter in 7 minutes with hand tools and it took me 3 hours with air tools.... /forums/images/graemlins/tongue.gif
   / TC 55 Steering #39
Meledward23,
I have now 12hrs on my TC55DA EHSS with 18LA and loaded tires. The only way I can lose the power steering for a few seconds is if I have something that heavy in the bucket (around here in N.S. there are tons of rocks), that it almost picks up the rear end. It always came back after going a little forward or reverse. It seems to be that one is worse than the other. The other question is: Is your tractor level when that happens or are you on a slope? For me it only happened while being level.
Like you said before on our tractors it only happens once in a little while and that's it. I would be thinking the same thingyou said. Could it be something like not enough hydraulic oil in the power steering or air in the lines?
On a differnt note: Does your main Haudraulic pump make a noise when cold (0 C) until the tractor warmed up?
I ran out of work to do with the tractor in the moment, but later I will cut some more logs and then I will see what happens. /forums/images/graemlins/wink.gif
   / TC 55 Steering #40
Zero C? You wont find me outside in that temp. much less on a tractor........
I have noticed around 45 degrees F. that there is a little groaning for about 1 minute under my right foot till the tractor warms up.
I am primarily on level ground 99.9% of the time. There are only two inclines on my property.
BTW, congrats on the tc55 purchase, hope you enjoy it as much as I have....
2015 PETERBILT 389 FLATTOP (A58214)
2015 PETERBILT 389...
WOOD GRABBER FOR MINI EXCAVATOR (A58216)
WOOD GRABBER FOR...
BOY ON JOHN DEERE TRACTOR PULLING JOHN DEERE WAGON (A58374)
BOY ON JOHN DEERE...
TEST YOUR BID BUTTON! (A52708)
TEST YOUR BID...
POOBOO C-580 INDOOR CYCLING STATIONARY BIKE (A58374)
POOBOO C-580...
2013 Yamaha YDREX4 Electric Golf Cart (A56859)
2013 Yamaha YDREX4...
