TC18 60" MMM
   / TC18 60" MMM
Re: TC18 60\" MMM
the bolt is broken flush with the transmission housing, as is the easy out. i don't know how to weld, but my father-in-law can. I wonder if you can weld a smaller bolt to the first one?
   / TC18 60" MMM #12
Re: TC18 60\" MMM
</font><font color="blue" class="small">( Worst part about that is, it is under the tractor. You would have to get wax to run UP!! )</font>
Don't worry.. it will /forums/images/graemlins/shocked.gif.. it will 'wick', due to capilary action..
Soundguy
   / TC18 60" MMM #13
Re: TC18 60\" MMM
</font><font color="blue" class="small">( the bolt is broken flush with the transmission housing )</font>
Ideally, you would start with a stub.. however.. flush is still doable.. You put a nutright over the hole.. use one that only gives you access to the broken piece.. not the sourounding area... probably end up being a smaller nut than the bolt head was.. but should still work...and then be carefull about only welding the shank to the nut.. stick welder with a small 1/8 rod probably easiest way to do this... once it isn't red anymore, try it.
Soundguy
   / TC18 60" MMM #14
Re: TC18 60\" MMM
Soundguy explained it well(better than me).
If your FIL is a decent welder, this should be no problem.
   / TC18 60" MMM
Re: TC18 60\" MMM
that doesn't sound too bad. I might give that a try. After the previous problems I'm nervous about running with only 3 out of 4 bolts.
JOHN DEERE 330G SKID LOADER (A58216)
JOHN DEERE 330G...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58216)
PALLET OF 15 4 X 8...
Ford Super Duty Pickup Truck Bed (A55973)
Ford Super Duty...
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2021 Chevrolet Tahoe SUV (A56859)
2021 Chevrolet...
