TC18 60" MMM
   / TC18 60" MMM
Re: TC18 60\" MMM
the bolt is broken flush with the transmission housing, as is the easy out. i don't know how to weld, but my father-in-law can. I wonder if you can weld a smaller bolt to the first one?
   / TC18 60" MMM #12
Re: TC18 60\" MMM
</font><font color="blue" class="small">( Worst part about that is, it is under the tractor. You would have to get wax to run UP!! )</font>
Don't worry.. it will /forums/images/graemlins/shocked.gif.. it will 'wick', due to capilary action..
Soundguy
   / TC18 60" MMM #13
Re: TC18 60\" MMM
</font><font color="blue" class="small">( the bolt is broken flush with the transmission housing )</font>
Ideally, you would start with a stub.. however.. flush is still doable.. You put a nutright over the hole.. use one that only gives you access to the broken piece.. not the sourounding area... probably end up being a smaller nut than the bolt head was.. but should still work...and then be carefull about only welding the shank to the nut.. stick welder with a small 1/8 rod probably easiest way to do this... once it isn't red anymore, try it.
Soundguy
   / TC18 60" MMM #14
Re: TC18 60\" MMM
Soundguy explained it well(better than me).
If your FIL is a decent welder, this should be no problem.
   / TC18 60" MMM
Re: TC18 60\" MMM
that doesn't sound too bad. I might give that a try. After the previous problems I'm nervous about running with only 3 out of 4 bolts.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
KARAVAN S/A BOAT TRAILER (A52708)
KARAVAN S/A BOAT...
More info coming soon! (A55851)
More info coming...
SET OF TRUCK FENDERS & HARDWARE (A58374)
SET OF TRUCK...
Mc LANE EDGER (A58374)
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
