TC33D Glow Plug Issue
   / TC33D Glow Plug Issue #11
Again, this refers to Class III Boomers, but it may be helpful.
Attached, location of Glow Plug Timer.
   / TC33D Glow Plug Issue #12
   / TC33D Glow Plug Issue #13
Glow Plug Timer Troubleshooting.
   / TC33D Glow Plug Issue #14
   / TC33D Glow Plug Issue #15
I don't know if this any help, but I too have a TC33D with a glow plug light that acts like it has a mind of it's own. I have noticed that even with the light not operating that the timer still seems to be ok. I can hear an audible click when it cuts off the power to the glow plugs. I've learned to just listen for the click noise before I fire it up. May not be your problem, but I wanted to throw it out there just in case.
   / TC33D Glow Plug Issue #16
   / TC33D Glow Plug Issue #17
I couldn't tell from the diagram if the relays were on the right or left but on the 03 33D they're behind the right kick panel (or knee banger as PineRidge put it).
ohmboy has a good suggestion to listen for the click, I sometime glance at the light but listen for the click more often than watch the light. If it's cutting out to quick, I would probably replace that before the ignition switch.
   / TC33D Glow Plug Issue #18
   / TC33D Glow Plug Issue #19
I had the same glow plug problem. I replaced the glow plug timer relay first, which did not solve the problem. Replacing the ignition switch did fix it.
   / TC33D Glow Plug Issue #20
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
Hydraulic Hose and Fitting Replacement Pack (New/Unused) Est Retail Value $2,650 (A59225)
Hydraulic Hose and...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56436)
2023 Kubota Z412KW...
Giyi Auger (A57149)
Giyi Auger (A57149)
2019 Bomag BMP 8500 Trench Compactor (A57453)
2019 Bomag BMP...
2024 LandHonor PHA-16-2C Three Point Hitch Adapter Skid Steer Attachment (A56857)
2024 LandHonor...
