TC33D Will Not Start
/ TC33D Will Not Start #1
thclimer
Eastern NY
New Holland TC33D, Massey 1736
Here is the situation, ran little blue (TC33D) about a week ago with no problems, parked her in the garage. Last night went out to start her, turned the key and waited for the glow plug light to turn off then continued to turn the key, starter did not engage, just a very faint tic. Upon investigation of the fuses found that the 10amp one for the turn signals was burned out. I can't imagine that this was stopping the starter motor from being powered. I check the seat switch by pulling the connector and verifying continuity when the switch was made, also checked that the parking break was on. Charged the battery to make sure that wasn't the problem. Tried moving the gear selector into and out of the two neutral positions, confirmed that the rear and mid PTO was disengaged. I'm certainly no electrician but is there an easy way to confirm all the safeties are not stopping the circuit from being completed. Would it be worth trying to find the starter solenoid to determine if power is getting to it? Where is it and what would I connect to verify power? I'll pickup a new 10am fuse tonight on the way home. Thanks for you help, Tim
/ TC33D Will Not Start #2
Here's a link to a thread that might help you resolve the problem.
BTW, I did a Search of the NH Owning Forum for the words 'wont start'. Of course, I had to first remember this thread. /forums/images/graemlins/smile.gif I hope it helps you resolve your problem.
/ TC33D Will Not Start #3
Just looked at the schematics for mine and the hazard and turn signals use a 15 amp fuse. The safety switches use a 10 amp, it's fuse 5 in my book. If it was truly a 10 amp fuse blown then I'd suspect it is the safety switches fuse.
Well it's always the simple things......as David pointed out in his post, either my manual is wrong or I didn't read it correctly, it was the 10amp fuse which was the problem. I left my manual at work so I'll look again at it tomorrow. I wasn't looking at the schematics rather the page which shows the entire fuse block with them numbered and what they do, from what I can remember it was #5. Now why did the fuse blow in the first place? At least I'm back running, thanks for your help, Tim
/ TC33D Will Not Start #5
The same thing happened to me twice when my tractor was new. The first time was when I had the lights on, and second I think I hit the starter before the glow plug went out. I repeated these mistakes since, but I didn't repeat the problem. Someone awhile back determined that if the battery voltage is low, an over current situation can exist and burn that fuse. The batteries have tendency to sit for long periods of time without starting prior to purchase, so they may not be properly conditioned when first purchased.
/ TC33D Will Not Start #6
My TC33 did the same thing at 19 hours............When my wife shut it off to fix supper..............The battery was fully charged.........It turned out to be a faulty ignition switch which they eventually fixed under warranty...........If the fuses keep blowing .........Look further........There has to be a reason!! If you need any more info I have copies of the dealers service advisory from the NH ASIST tech system (which hilites the problem) I can fax you...........Good luck...........TOM
I got my manual and I'm still a little confused (see attached page 1, 2, 3). If you look at page 1 this is the one I was looking at, fuse #5 is the one which blew that I replaced. Looking at page 3 it indicates #5 to be a 7.5amp fuse, it was a 10amp that I replaced. Page 2 is titled the Safety Starting System and seeing the 7.5amp fuse confused me. Maybe its because the sheets are all cut onto separate pages. I think I'll photo copy and tape all together trying to connect all the lines. Something still doesn't match up with the number 5 fuse on page 1 and 3. Tom thanks for your offer to fax me your paperwork, if I have more problems I'll be in touch, I think I'm fine for now. Tim
Here is page 2
Here is page 3
/ TC33D Will Not Start #10
Looks like you got a wrong manual. Following is the same pages in my manual.
/ TC33D Will Not Start #11
Here's page 3-40.
/ TC33D Will Not Start #12
Here's page 3-42.
My manual is version 10/02. You might want to get your dealer to give you the correct manual for your machine.
/ TC33D Will Not Start #13
Originally, when the dark gray bodied tractors were introduced, fuse 5 was a 7.5 amp fuse. This was changed to a 10 amp fuse because of the problem you are having. In some circumstances this was not a total fix. The latest is to install a 10 amp circuit breaker, which you can get at NAPA or other parts store. The breaker will fit into the fuse holder like a fuse. The breaker will come with contacts that can broken off at preset lengths so it will fit in the place of the fuse.
As for the wiring diagrams, the early books for the dark gray tractors had several errors. All the diagrams posted are for the dark gray tractors, just different issue dates.
It's clear now that I do need to talk with my dealer. My manual has an issue date of 3/02. I purchased my TC33D in 9/02. Mike do you know what a good issue date might be?
Thanks, Tim
/ TC33D Will Not Start #15
I have not looked closely at the newer manuals to see if the errors were corrected, but I would assume they have been. The manual you received was probably the one that came with your tractor even though there is a difference in the months between issue and when you bought your tractor. Any dated after 10/02 should be alright. If my memory serves me right, the correct wiring diagrams will have wire numbers exceeding 100 at the range or pto safety switches. 105 or 108 I am thinking. Hope this helps.
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
2011 Tri Axle Frac Blender Trailer (A64194)
2011 Tri Axle Frac...
John Deere 2 Row Planter (A65640)
John Deere 2 Row...
2012 Mack CHU613 Day Cab Truck, VIN # 1M1AN09Y6CM010558 (A65563)
2012 Mack CHU613...
