TC33D won't start.
   / TC33D won't start. #1
JGM
I can't start my tc33d. Turn the ignition switch to on and the PTO light up. I did some checking and noticed the Hydraulic fluid was low.
A mechanic told me that if the oil gets too low, the tractor won't start. First Question, when measuring the oil, do you insert the dip stick all the way down or do you measure leaving the bottom of the dipstick's rubber seal out when measuing. Sometimes you see instructions stating not to screw the dipstick back in place when taking a measurement.
Also, are there any wiring issues that might cause this problem?
OR..... is there another problem.
oh yea, a couple days I was having a hard time moving the loader shifter over to dump a load. My son was on it later in the day and said he heard a pop and the loader started operating fine. I am unsure if the two incidents are related, but thought it might be... thoughts?
thanks, joe
   / TC33D won't start. #2
Hey Joe
I used to keep some 15 amp fuses on the tractor after getting stranded. The 10 amp starter fuse used to blow a lot. Also check your battery mine leaked after just 50 hours.
   / TC33D won't start. #3
Hi Joe,
I'm not aware that if the level of hydraulic oil was low it would not allow the tractor to start, but I can tell you there are a host of electrical issues that will. Probably the best post to read is the following one:
http://www.tractorbynet.com/forums/new-holland-owning-operating/124642-tc33d-wont-start.html
After replacing my fuse with the circuit breaker style fuse and a more robust ignition switch, the final fix for me was to install the relay.
There is a wealth of information here, good luck at getting her running again.
I doubt the loader issue has anything to due with the tractor not starting.
so after reading the previous thread(s), are you saying switch out the battery cables?
one point i faild to mention earlier. On Saturday, i was mowing with it and noticed i had to get fuel. So I disengaged the pto, drove it to the gas station. I was about to turn it off but noticed the PTO light was still lit even though both PTO levers were off. I jiggled around with it and turned off the engine.
I fueled up, tried to start it and nothing happened.
just thought i would throw that in as my problem doesn't exactly mimic the problems with the sticky TC33D thread.
thanks joe
   / TC33D won't start. #7
Mine seems to want to eat a 10 V fuse every year (next to the top fuse). I keep a supply in the toolbox and am started up and running with just a few minutes of effort.
   / TC33D won't start. #8
When you turn the ignition key does the tractor turn over, but just not start?
Jinman is an expert at this stuff, but I think if your PTO light is on and you turn the key and it turns over but will not start you might have fuse #2 blown.
Have you checked all your fuses?
With the PTO light on I believe the tractor will not start, even turn over because of a safety interlock, so if your fuses are not blown and the tractor thinks the PTO is engaged I don't think it will start. Your PTO lever or switch might be out of adjustment.
   / TC33D won't start. #9
Joe, forget the hydraulic fluid level having anything to do with starting. It does not.
If you turn on your key and the PTO light comes on (with the PTO lever to OFF), it is one of two things. You have a fuse blown or the PTO switch is out of adjustment. I would look for a blown fuse first. If that doesn't work then jiggle the PTO lever to see if you can get the starter to work. I'm not exactly sure where the PTO switch is or how to adjust it on the TC33, but it sounds like it is out of adjustment based on your saying it caused you problems at the gas station. One thing is for sure. If the tractor thinks the PTO is ON, it will not start. That's how it is supposed to operate.
   / TC33D won't start. #10
Time to switch to a circuit breaker? :)
159118 (A60430)
159118 (A60430)
2024 JOHN DEERE 250P EXCAVATOR (A60429)
2024 JOHN DEERE...
1660 (A59213)
1660 (A59213)
2014 Ford Explorer SUV (A59231)
2014 Ford Explorer...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
