tc40 wont start
   / tc40 wont start #22
Good for you, stonecomm. I think we've learned that air may be introduced into the system by a bad hose, but I don't know why the hoses weren't leaking and self-bleeding.:confused: There is no pump from the fuel tank to the injector pump. It's all gravity feed, so there is no suction except the injector pump. If it started, you are obviously good to go.:thumbsup:
   / tc40 wont start
what is the unit in between the filter and injector pump. there is a fuel line from filter to ? then from ? to injector pump.its mounted on the side of the block under the ignition switch
   / tc40 wont start #24
I'm on the road on vacation and don't have my manuals as a "crutch," but I believe what you are seeing is the injector bypass line. It takes excess fuel from the injectors and routes it back into the supply. You might also be seeing the hose that comes from the fuel tank behind the operator. It is routed up under the platform and to the fuel filter.
   / tc40 wont start
On Vaca and still checkin in Diehard member! I need to get myself a manual also. Next project is to adjust the eccentric so it stops creeping on me Should be fun with the loaded tires.
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
UNUSED LANDHERO 1H-1W21 1" AIR IMPACT WRENCH (A57193)
UNUSED LANDHERO...
2005 John Deere 310G 4x4 Extendahoe Loader Backhoe (A55851)
2005 John Deere...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
