tell me about "I-match"
/ tell me about "I-match" #41
Re: tell me about \"I-match\"
Oddly, the newest pics from JD show the same part number in a different finish. The black oxide finish did bother me a bit. I smeared some grease on them and so far so good.
Hopefully this pic is hyperlinkable...
This finish is much more desirable and similar to what you probably have, Mike. I wonder if JD changed it up a bit?
/ tell me about "I-match" #42
/ tell me about "I-match" #43
</font><font color="blue" class="small">( so there are two different bushing kits from JD for the imatch?)</font>
At least 2. Actually, I think there are 3.
The term "bushing" is a bit loose here.
My 665 tiller has a captured pin setup and not compatible with the "bushings" I posted pics of. Since the pins are too small for I-match, they need to be sleeved up a size (or two?)... a true bushing application.
But for pins that attach to the implement on only one side, the part I posted pics of works better, in my opinion, than bushings you would use on a captured pin setup. This is because you need something to hold the bushing on the pin. This something, I think called a snap ring, is hanging out there just asking to get mangled. And mangle I did. So I looked for a better solution.
So there are the true bushings (short tubes that convert from cat 1 to cat 2, or cat 2 to cat 3, etc) and there are the shouldered pin gizmos I posted pics of. I guess they are bushings... but bushings typically don't have pins going through them and a big shoulder on one side...
/ tell me about "I-match" #44
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2014 American Signal Solar Towable Message Board (A59228)
2014 American...
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
