tell me about "I-match"
   / tell me about "I-match" #41
Re: tell me about \"I-match\"
Oddly, the newest pics from JD show the same part number in a different finish. The black oxide finish did bother me a bit. I smeared some grease on them and so far so good.
Hopefully this pic is hyperlinkable...
This finish is much more desirable and similar to what you probably have, Mike. I wonder if JD changed it up a bit?
   / tell me about "I-match" #42
   / tell me about "I-match" #43
</font><font color="blue" class="small">( so there are two different bushing kits from JD for the imatch?)</font>
At least 2. Actually, I think there are 3.
The term "bushing" is a bit loose here.
My 665 tiller has a captured pin setup and not compatible with the "bushings" I posted pics of. Since the pins are too small for I-match, they need to be sleeved up a size (or two?)... a true bushing application.
But for pins that attach to the implement on only one side, the part I posted pics of works better, in my opinion, than bushings you would use on a captured pin setup. This is because you need something to hold the bushing on the pin. This something, I think called a snap ring, is hanging out there just asking to get mangled. And mangle I did. So I looked for a better solution.
So there are the true bushings (short tubes that convert from cat 1 to cat 2, or cat 2 to cat 3, etc) and there are the shouldered pin gizmos I posted pics of. I guess they are bushings... but bushings typically don't have pins going through them and a big shoulder on one side...
   / tell me about "I-match" #44
2014 Ford F-450 Dump Truck, VIN # 1FDTF4GT9EEA61310 (A54865)
2014 Ford F-450...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52707)
KNOW BEFORE YOU...
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2001 AMADAS 2100 LOT NUMBER 251 (A53084)
2001 AMADAS 2100...
2013 Nissan Rouge SUV (A53424)
2013 Nissan Rouge...
