Terra-Dome Earth Shelter Build
   / Terra-Dome Earth Shelter Build #911
Congratulations on sealing your roof. I really admire your determination and problem solving skills. That's the best part about threads like this and alternative building methods, the discovory and creative process that leads to new ideas!!!!
I tried to find what you used to seal the concrete, but either missed it or got confused. What did you use that worked?
Thanks,
Eddie
T
Pole Shift as described in some of the links listed in this thread way back is so full of bogus BS that it makes astrology look like real science. Magnetic pole shift is happening all the time; but the Pole Shift described in this thread is just plain ridiculous. If it happened in the short period of time as the PS'ers think it will, the earth will tear itself apart and make the Japanese quake of last year look like a speed bump.
The damage from a pole shift could be minimized by a great loss or reduction in the magnetic field and or gravity around the earth, which will allow the solid external surface of the earth to move freely from the inner core of the earth during the shift. The science for turning solids into liquids or removing the effects of gravity has been well documented by John Hutchison The John Hutchison Effect.
I do agree with you that much of the information is bull and designed to create fear which is much like any channel you could pick on your TV. The human race is waking up. Our numbers seem small now but this process will speed up. We all know the information provided is missing the truth. Most of us who have looked a the preponderance of information know differently and wish to share so that we all can be safe and understand we have choices. We share because we care. We may be wrong at times but we search because we are guided to do so. I believe this is the internet revolution of knowledge.
Thanks,
Eddie
We used Berylex on the roof and parapet concrete mix. Epro ECOLINE-R Liquid Applied Membrane, EPRO Polyester-160, Tremco Paraseal a multi-layer sheet membrane with self-sealing expandable layer of granular bentonite, ECOTAPE Single Coated Polyethylene Tape, Halliburton CASING SEAL and Stego 15 ml vapor barrier. We use 3 inch electrical conduit with holes drilled every where except bottom covered with a filter sock to remove water.
Sam, you've created an unbelievable home while taking self-reliance to the level of an art form. Your dogged persistance of getting the highest quality has been obvious in everything you do. Your family being included so heavily to bring about success is just amazing. I can't help but wonder about your boys and whether they will soon branch out on their own lives or live there with you as they decide to have their own families. It's none of my business, but I still wonder. Most of us who have followed your thread from the beginning will always have mental images of your home in every stage of building. Thanks for posting and thanks for any updates you might choose to give us.:)
I just hope that they don't build a highway, a reservoir, or airport near to your location. Oklahoma is a beautiful place and being rapidly "discovered." With population growth, there comes all those things that could make your life miserable. Of course, you work for the Army Corps of Engineers, don't you? You might have the inside track on info that the rest of us don't know. I just think that population growth and metropolitan growth have the most likely chance of being the thing that causes you the most angst in the future.:confused3:
Our sons will stay close by until this period of unrest passes. They understand first hand you can achieve anything and we all are only limited by our imaginations. I am sure they will make me proud in what ever they choose to do but as you said it will be interesting to see.
We love the location of our home and all that nature provides. We don't know what is going to happen but if any growth is to occur jobs must proceed.
   / Terra-Dome Earth Shelter Build #915
The concept of an EXPERIMENTAL house classification could be interesting; but it would still need to meet some sort minimal standards just as the FAA requires EXPERIMENTAL planes to meet certain standards. The biggest downside to an EXPERIMENTAL house classification with little to no standards is that we regress backwards to a time when people built whatever they felt like regardless of safety. Too much regulation as in California is bad; but too little can have negative consequences too.
If you read the Class K stuff, you will see it applies to homes on at least one acre. Yes, you still must comply with electrical and sanitation codes. It is a good common sense approach to the right of someone to provide their own shelter. A far better solution than making folks live under bridges if they have a piece of land but not enough money to build what houses have become these days.
Pole Shift as described in some of the links listed in this thread way back is so full of bogus BS that it makes astrology look like real science. Magnetic pole shift is happening all the time; but the Pole Shift described in this thread is just plain ridiculous. If it happened in the short period of time as the PS'ers think it will, the earth will tear itself apart and make the Japanese quake of last year look like a speed bump. Plate tectonics is a proven fact; but the plates move tiny amounts each year requiring millions of years to shift any great amounts to be visibly noticeable. The Himalayas were created as a result of India crashing into south Asia. The Alps are a result of Africa ramming into Europe. Earthquakes are a result of the plates grinding into, past, and under each other.
The Yellowstone super-volcano is a result of that part of the country being over a hot-spot in the mantle. Hawaii is over a hot-spot too.
Scientific facts, or hypotheses, there is, in the geological record, reason to believe that the terrestrial poles have occupied diverse points on the globe, suggesting that at least the crust was in widely varied planes of rotation, around these diverse points. Whether the incline to the ecliptic was much different or not, is not so easily deduced. One such likely position of the rotational axis is the area of Lake Chad. More than simple 180 degree geomagnetic reversals seem to have happened at some time in the past. When we look back, we are left to guess what things mean. Whichever analysis is in vogue at any one time is usually held for about a generation past the time when any error is first brought to light. Such is the inertia of the academe.
On another front: there was a 4.0 Richter quake near the old New Madrid epicenter at about midnight there.
   / Terra-Dome Earth Shelter Build #916
Please see comments in red.
OK...when Stephen Hawking, the scientists at Fermi Lab, and CERN endorse Hutchison, I will give him some credence. But most of what I found on the guy seems to indicate he's a fraud. Regardless of what one may think of Wikipedia, they don't have an entry for him or his effect either. One video I found on YouTube made by him appeared that he was dressed in women's clothing. Eccentric is one thing; but this guy looks and sounds like a fraud on the order of Jimmy Swaggart, the Bakers, Amy Semple McPherson, Al Sharpton, Jesse Jackson, and a plethora of others. The web site you provided is so amateurish in its execution that it looks like it was created by a 14-year old going for whiz-bang effects instead of fostering a professional image of someone who should be taken seriously. P.T. Barnum was right.
I re-read the link more thoroughly, and it's interesting. It almost sounds like a way for California to collect fees without having to do the work. A good way to cut the expenditure of time, manpower, and money; but not revenue, especially on the new construction front.
Here is an interesting article on "Super-continent Cycles" that makes more sense than geographic poles shifting wildly, especially after the the early Earth settled into a stable orbit.
Supercontinent cycle - Wikipedia, the free encyclopedia
   / Terra-Dome Earth Shelter Build #917
I am on the side of the catastrophists, not the uniformitarians. Uniformitarianism has ruled the day in the academe for a long time, but has been eroding as time goes by. These are but hypotheses, and they will be in battle until we have built a working time machine. We will just disagree, unless we are published professors, in which case, we will do whatever is necessary to keep our views dominant. This is the history on Schmience. It's not a proud record. To me, it's not worth the fight. I'm just a high school dropout, and don't have the vested interest. If you knew my theories, you'd probably be calling me a crackpot. And that could be correct. Even at that, we'll never know for sure.
   / Terra-Dome Earth Shelter Build #918
Sam , it`s nice to see you back.....I`v always appreciated your perspective, and enjoyed your work.....I personally live in a more `immediate` weather disruptive area S C coast, and each year try and get prepared for what ever `mother nature` throws our way....That keeps a person thinking.....I don`t worry so much about `gargantuan phenomena` but there really isn`t that much difference :)
Do you have your roof water tight? No leeks? Tony
A few pics
More pics
Chevrolet C8500 Flat Bed with a Moffet Kit (A52748)
Chevrolet C8500...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
378801 (A51572)
378801 (A51572)
Case SV 340 Skid Steer Loader (A52349)
Case SV 340 Skid...
