I happen to do a considerable amount of business with a company that replaces about 8000 to 10,000 vehicle engines a year. Do you want to know what is by far the most common reason for the engine failure? Lack of proper lubrication due to motor oil that tests out at being far past it's usable life. Since this is an indisputable fact, I'm likely never going to push any 20k miles between oil changes. Just because you do one, two or even ten oil analysis', exactly how do you know if or when your engine starts to break down it's oil prematurely due to contamination, a defective filter, a poor batch of oil, a defective air filter, etc., etc., etc.? The fact is you don't.
Since it would be a rather difficult task to challenge the manufacturer's recommended interval that ranges between 5k to 10k, I personally think you're playing with fire (based on what I see every day) by pushing it past that mark. I'll readily admit that I used to do my oil changes at 3k right on the button for decades. Heck, I am the guy who even keeps a little log book in the glove box that not only logs each and every oil and filter change, but also every single thing done to the vehicle except filling it up with fuel.
I know of dozens of Chrysler/Dodge and Toyota dealerships that
required the use of synthetic oil in the engines that were known to be troublesome; i.e. the 3 liter Toyota and the 2.7 liter Chrysler. The dealerships couldn't actually "require" the customers to use synthetic oil in those engines, but the customers who did so basically never experienced the sludge problem that is well documented with those issues. If I recall it correctly, both manufacturers refer to the issue as "premature gelling of the lubrication".
Anyway, I digress. I do feel that changing oil every 3k is a waste of money. However, based on experience, that waste of money is generally not as much as the financial loss from those who tend to push their oil too far. I'd have to say that it would be a good plan to either follow your onboard oil monitor or go by the manufacturer's recommendations. Either way, I believe you're covered quite well and are not likely to become one of my statistics.
