the auger wont drill the hole
   / the auger wont drill the hole #21
How do you have your hydraulics connected?
I have a down pressure kit as well that I connected directly to a remove, and there is no pressure relief, so while it worked great at first, I managed to break the bracket with too much down pressure.
Your bracket looks like a much stronger design than mine for sure. I don't think I would have been able to break/bend something like that!
   / the auger wont drill the hole #22
mine has 2 hoses. one connects to one of my remotes and the return line dumps directly into the hydraulic tank. ie: single acting cylinder.
My Kioti dealer got me the part that installs over the original hydraulic fill point on the tractor. it has a standard hydraulic connection and the hose just clips on.
This way as soon as i raise the arm, the hydraulic fluid dumps directly into the tank....non pressurized. I can not wedge the arm and bend it.
   / the auger wont drill the hole #23
Thanks. I'll have to look into that. With what I have now, when I release the remote lever, the cylinder is locked into its current position. I have to always remember to retract the down pressure cylinder before raising the auger, or crunch!
   / the auger wont drill the hole #24
Thats what mine did the first time i used it. I called my dealer and asked him. He was the one that told me that those assist units HAVE to dump back into the tank to prevent what your talking about. I believe the unit is the same part that they install on tractors that have the backhoes installed if i remember right. The part was like $40.00. took like 5 minutes to install.
   / the auger wont drill the hole #25
Excellent, appreciate the additional advice. Will talk to the dealer about it next time I stop by.
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2017 HINO 268 BOX TRUCK (A54607)
2017 HINO 268 BOX...
2002 VOLVO L150F WHEEL LOADER (A51406)
2002 VOLVO L150F...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2005 NORAM 65E MOTORGRADER (A52705)
2005 NORAM 65E...
1983 Case 580D (A47477)
1983 Case 580D...
