The Largest Diameter (29") Dead Tree That I Have Pushed Over
   / The Largest Diameter (29") Dead Tree That I Have Pushed Over
Not me, not on my burn pile!! :eek: :D
   / The Largest Diameter (29") Dead Tree That I Have Pushed Over #24
QUOTE]
Not at that stage of the fire. Later when all the smaller stuff has burnt away from the stumps and logs. That's when I use the grapple to gently place burnable material near each other to continue the intense burn from condensed piles.
hugs, Brandi
Right, but with a tractor on my big burn piles, I think the front tires would be in the hot coals and hot ashes.
Here is another old fire poker. :D
Started the fire Wednesday, this was Thursday:
This is from this morning, Friday. Haven't touched it, it just burned down flat:
Still have visible flames under the dirt and sand rock root ball:
Decided to flip it over with the forks. With the boom extended, there is just over 14 feet from the tips of the forks to where the tires touch the ground:
It should be through smoldering by the time the winds come up Saturday evening. :thumbsup:
   / The Largest Diameter (29") Dead Tree That I Have Pushed Over #27
This is the time I grapple and stack the sides without dirt onto the other stumps to keep the hot coals burning them up.
hugs, Brandi
Yep, I have done that too, but these three I will drop in the Brush Ravine:
   / The Largest Diameter (29") Dead Tree That I Have Pushed Over #29
I once had a stump pile that took 3 days to get going and near a week to burn out.
It had a berm of dirt around it shaped like a U and once it got going you could burn wet stuff.
John Deere 1025R (A53317)
John Deere 1025R...
2012 Peterbilt 389 Semi (A59814)
2012 Peterbilt 389...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
43023 (A59228)
43023 (A59228)
Kubota L3130 (A53317)
2009 MULTIQUIP 25KW GENERATOR (A58214)
2009 MULTIQUIP...
