Think about upgrading tractors but.......
   / Think about upgrading tractors but....... #11
That is a nice looking 2410 you have, thumbs up.
Thank you Jim.
What cab is that? Sims? Curtis? How do you like it?
It's a "Sims Cab Depot" cab, model is a "Indy Cab", It has two soft removable panels below the front windshield on both sides, and a soft removable clear panel at the rear (hard fixed panel would be in the way for using the backhoe). I really like it and in the summer I have just started removing the door for easier access.
I do believe Curtis still makes a cab for the MF GC2410 and since I have purchased my Sim's cab over 10 years ago, maybe there might be others that make a hard sided cab for the MF.
Here's a pic of what I usually will have installed on the MF in the summer.
KC
Thanks guys-I am looking at using the 3ph instead buying another machine. Cost and maintenance and parking are an issue.
   / Think about upgrading tractors but....... #13
Thank you Jim.
KC
I have a GC1710TLB. The only hard factory looking cabs I've found are the Sims and the Curtis even today. I would really love to have one in the winter but it's hard to justify the cost as The appear to be around $6k. I've often thought of buying a nice canopy and making my own modular cab system.
   / Think about upgrading tractors but....... #14
I don't know what the 3 point lift capacity is of your tractor.
But,I knew I had seen something to increase the lifting range of the 3 points and I found it again.
Titan calls it a 3PT scissor lift, I don't know if this would give you the lift needed or if your tractor could handle a ton with this much rear mount.
3PT Scissor Lift
   / Think about upgrading tractors but....... #15
Yes that is a lot for a cab, but if you got the soft sided rear panel (only style available in 2009) like I have you'd save $750 (2009, I paid $3995 which included a pair of work lights kit, a hot water heater kit, a pair of outside side mirrors kit, and installation).
And back in 2009, I thought it was a lot of money also, and I think if you did a search you might find different D.I.Y. cab builds.
Good Luck, KC
   / Think about upgrading tractors but....... #16
This is the one I have been looking at.
   / Think about upgrading tractors but....... #18
3PT Scissor Lift
That is a neat attachment. Thanks for posting the link.
2014 Forest River Rockwood Premier Pop Up Trailer (A59231)
2014 Forest River...
Toyota 8BPU15 3,000 LB Stand-On Electric Forklift (A59228)
Toyota 8BPU15...
2006 Acura RL Sedan (A59231)
2006 Acura RL...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2010 KMC 3376 Peanut Combine (A56438)
2010 KMC 3376...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
