I think I've narrowed down my search for a new CUT to either a Massey Ferguson 1652 or possibly 1648, a New Holland Boomer 3045 or Case/IH DX45 or possibly a Kubota 4740 or 4240. The NH and Case are basically the same tractor with similar financing but for whatever reason Case seems to be getting better financing right now strangely. All of these models will be cab models, as I am only looking at cab model tractors.
I will be using the tractor for taking care of roughly 7 acres. I will be finish mowing about 5 to 5.5 acres at least once a week and brush hogging a little less than an acre. I will also have a garden area. I also will be installing about an 800 foot driveway and using the FEL to help with snow removal once the driveway is in and the house is built. My plans are to run an 84" mowing deck and a 72" bush hog. I realize that all of these tractors are overkill for my needs, but I hate mowing the lawn and don't like getting dirty while doing it, so that necessitates a cab with air conditioning. I want to run an 84" deck as I plan on mowing at least once a week and want to be done in about 2.5 hours. This should be reasonable as this is basically an open field with trees only on the perimeter. Also I keep hearing that the AC robs a good chunk of power on cabbed units so I wanted to go a step up over the likely minimums necessary for running an 84" rear finish mower.
I've looked at all the big names and the tractors that I mentioned are the best overall values for me. I would rate the Kubota as the least likely tractor for me to purchase as it will likely be the most expensive and I would prefer a tractor slightly between the 4240 and the 4740, as I worry that the 35 PTO HP might be a little too small for the 4240, but I don't want to spend the extra $2K for the 4740. The JD 3720 and 4320 bore serious consideration too, but I think the 3720 is just too narrow for my likings even if for no reason other than cosmetics. Also JD dealers seem a bit too proud of their tractors and I haven't found any willing to go below about a 10% discount off MSRP.
So I'm looking at a MF 1652 cab, with FEL, HST, just the standard single rear remote and loaded R4 tires for about $37,000 out the door, delivered with 0% down and 0% APR for 72 months. I may see if I can get a similar discount on a 1648 as it is likely more what I need.
The Boomer 3045 will be a cab model with FEL, Hydro tranny and loaded R4's for about $32,500 delivered with 0% APR for 60 months. I've located a Case/IH DX 45 with 50 hours and a new tractor warranty for about the same money but would have to buy sight unseen from the dealer.
The Kubota 4740 cab equipped with quick attach FEL, 1 rear remote and a radio is about $36,500 delivered. A 4240 equipped the same is about $1,900 less.
So, is there anything I need to know about any of these tractors before making up my mind? Thanks in advance for the help.
