Thinking about selling dump truck and buying dump trailer
   / Thinking about selling dump truck and buying dump trailer #31
12’ dump with 4’ sides
Another nice thing about a 10 ton dump trailer is the possibility of hauling my excavator with it.
I wouldn’t want to load your excavator into a dump trailer. The ramps are super heavy for one thing. When you get the height of a deckover dump trailer and the weight of a 10 ton excavator the weight of the ramp is even more of a concern. Chaining machines in a dump trailer flat out sucks. Most people just Bluetooth bind them in dump trailers. It’s less of a problem than the previous issues but you can’t spin the machine in a dump trailer either.
It’s not a 10 ton excavator, but I know what you mean. I have my big GN to move it around if needed.
I just figured it’s there in a pinch if needed.
   / Thinking about selling dump truck and buying dump trailer #33
I haven’t had a dump trucks in a couple years. I have 3 dump trailers. I’m mostly using them for dumpsters on my construction job. Occasionally I miss my dump truck but it wasn’t big enough. I really need a tri axel dump if I was going to have one but I can hire the trucking done cheaper than that investment. I miss the ability to tow a machine to the job with the dump truck and then jump right into hauling instead of having to go get a dump trailer first. The dump trailer also takes forever to dump. It’s rare that I would haul over 2-3 loads a day so it’s not a big issue but site hauling like your 200 load log job is painfully slow in a dump trailer.
   / Thinking about selling dump truck and buying dump trailer #34
I honestly would consider the dumpster and roll of type package, if its a lot of demo/debris. You open up a whole other business option, of just dropping a dumpster, and pick up after customer has it full. With that; this isn't an internet ad and cover page decision; and i would Definitely get real world numbers from them; trailer weight, dumpster weight; dump cycle time; dump angle; which they arent going to just list of spec sheet.
I also don't know how enforcement is there; while, yes, your ram and a 25,900 trailer would go though scales/ag stations, around here they are waved through; and generally left alone. Dump truck, most local guys arent harassed either, except certain places (restricted bridges); Motor Carrier Compliance general target OTR guys.
I don’t do much if any, dumpster stuff. I’d rather have a 7 gauge steel bed for rock, logs or stumps.
Yeah not much problem with scales and that nonsense round here, either.
I could do a dump trailer up to 38,000LB, but that’s not really what I want to do.
   / Thinking about selling dump truck and buying dump trailer #36
I want a rolloff truck. But the lighter duty ones don’t haul enough weight. Id want at the absolute bare minimum an F750 that can haul 7-8 tons legally but I’d probably just buy a tandem axle at that point.
   / Thinking about selling dump truck and buying dump trailer #37
That’s a valuable insight.
Someone must offer a gas engine/hydraulic pump combination for a dump trailer.
I'd be surprised if they made a elec/hyd with enough reservoir capacity for a telescoping cylinder. and I've never been impressed by them for anything much more than a lift gate.
Any chances that you might make some short sideboards for the proposed 24' hay/log trailer for dump truck chores?
   / Thinking about selling dump truck and buying dump trailer #39
Lots of dump trailers are using telescope hoist. They aren’t as big as what a tri axel dump truck uses but they don’t need to be. 2 out my 3 dump trailers are telescope hoist.
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2018 MACK PINNACLE (A53843)
2018 MACK PINNACLE...
John Deere 5075E (A53317)
John Deere 5075E...
ZETOR 4340 TRACTOR (A57192)
ZETOR 4340 TRACTOR...
1990 Ford F-450 Heil 10FT Dump Truck (A55852)
1990 Ford F-450...
2016 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2016 Ford F-550...
