Thinking of buying my first tractor. TC26DA or TC34DA??
   / Thinking of buying my first tractor. TC26DA or TC34DA?? #61
kumichou said:
I too am a NE Ohio member (Hiram area) and new to the forum. I'm also looking at either a TC26DA or a TC34DA. I have a 4 acre lot that I want to mow, along with putting in a decent sized vegetable garden, installing drain tile in the back of the lot and eventually building a 30'x40' workshop. Widening the gravel driveway is also on the list of things to do. I also would like to get a FEL for moving ground, gravel & mulch.
As for a mower, I'm looking at getting a rear mounted finish mower after reading about MMMs. Anyone have opinions of going with a multi-blade finish mower versus a flail (hammer-knife) mower to cut their lawn?
The lot was part of a farm, so the ground can be soft in parts when it's wet. Will turf tires really make a huge difference over the R4s? I'm not looking for my lawn to look like a golf course, but I'd like to not tear things up too badly & make mud patches.
For putting in the vegetable garden, is it worth the extra expense of investing in a 3pt rototiller versus using a 2 bottom plow & disc?
kumichou: Welcome to TBN :D! Plows and disc's work best for long garden "runs" and you really can not turn with them when ground engaged. I have had PTO driven tillers for 20+ years. They provide a degree of "control" that plows and disc's cannot- you can "spot" till an area with a tiller without moving forward, etc. Jay
kimochu,
You should go with the TC34. The 26 is too small. I have the R4 tires and they can do some damage to the lawn if you run the tractor on it when wet. I've got quite a bit of mud in the side yard when I am currently moving dirt from one spot to another. The ground is wet and soft and there's no way to go through there wuithout the tires digging in.
I'm glad I went with the R4 tires. I think I would have been stuck in the mud with the turf tires.
Greg (wild4Nature)
dateacher,
I'm thinking about getting a front mounted dozer / plow blade. I think it will be useful for pushing snow and moving dirt to help get it graded. I have a rear box scraper, but that's not going to push the snow to the side like my Meyers plow on the truck does.
I think you are right to hold off on modifying your set up for snow. It doesn't seem to be a big problem this year.
Greg (wild4nature)
   / Thinking of buying my first tractor. TC26DA or TC34DA?? #64
I have a TC 29 in Newton Falls, Oh. I use a tiller and it works great. I have a MMM and it does a good job. I also have a 7308 FEL. I have loaded turfs. I also have a woods backhoe. Turfs will spin in mud and do not compare to R-4 tires but since I bought this TC 29 in 1999, It has not been stuck to the point of being pulled out. Might have needed the FEL or backhoe but it came out. Turfs are good if you are going to do alot of mowing.
   / Thinking of buying my first tractor. TC26DA or TC34DA?? #65
wild4nature said:
kimochu,
Greg (wild4Nature)
Agreed, I have turfs on my lawn tractor. I need chains in mud.
Bob
   / Thinking of buying my first tractor. TC26DA or TC34DA?? #66
For seven years I used nothing but loaded turf tires and a FEL for moving snow on my driveway. Worked very well, I had a rear mounted snow blade on the back but never used it. When I sold the tractor on ebay the plow went with it.
oleozz,
Well if we would ever get any snow I might be able to find out. Unusually warm this year.
Not that I'm complaining. I'm enjoying the mild winter.
Greg
   / Thinking of buying my first tractor. TC26DA or TC34DA?? #68
Greg
Greg, same here! I rode my bicycle to work yesterday.
Bob
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
2018 GMC 2500 4x4 Crew Cab (A52384)
2018 GMC 2500 4x4...
LMC LOT IDENTIFIER 129 (A53084)
LMC LOT IDENTIFIER...
