Third time my tractor nearly killed me
   / Third time my tractor nearly killed me #61
I have a 2004 JD 4120 with 300 hours on it. Original owner. My ground is very steep, where you can only go up/down. I was brushhogging my field and I just started going down the crest of my hill and my transmission popped out of 'B' gear into neutral-- I was in 2wd. Even with the rear wheels locked up, the tractor picked up speed and was going over 20mph by the time I reached the bottom of the hill. How I didn't flip... no idea.
Anyway, this has happened two other times over the last 13 years resulting in real pants-filling experiences. I forgot my rule: always gear 'A' and 4wd, as it has never happened.
I really need to get this fixed, if there is something to fixed, as I dare not let my kids use it. Any suggestions?
Thanks,
Just curious as to the lay of the land. Is it open with no trees to hit and how long is the hill. I have a hill with a bunch of trees where it is in 4 whl lo all the way, both ways. Trees won't give much.
From advice given on this thread I think I will leave mine in 4wd all the time because I very seldom go on roads except for a 1100' blacktop drive.
   / Third time my tractor nearly killed me #62
I have a B Kubota that is four wheel drive and not sure with it but I also have a 5525 JD with four wheel drive and it has two options with four wheel drive. One is full time and other engages when needed. Which means rears need help. But if I have the JD in either of those four wheel options it affects the sharp turning of the tractor. It will not turn as sharp. Made those turns too many time doing tillage. So that makes me think there is a difference in the four wheel drive at least on my model or my tractor. On the Kubota have never notice any difference between four wheel and two wheel on turning but seldom use it in four wheel drive doing anything with tight turns.
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2014 TAKEUCHI TS70R SKID STEER (A51246)
2014 TAKEUCHI...
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
CAT 973 (A47384)
CAT 973 (A47384)
2005 Frieghtliner 18' Box Truck (A52377)
2005 Frieghtliner...
