Those with lightning storms, how do you protect electronics?
   / Those with lightning storms, how do you protect electronics? #71
Lightening and surge protection is a specialized science . Radio and TV broadcast towers are designed to take a direct strike and return to operating within a few seconds . Grounding , bonding and voltage clamping is critical.
If the property had a drilled well. Run a #2 bare copper from the well casing to the main ground lug in the service entrance panel . No extra bends or sharp corners on the ground . Install a set of those surge suppressor 澱reaker in the main panel .
Not 100% protection but it will reduce some damage from some lightening strikes .
   / Those with lightning storms, how do you protect electronics? #72
One big point being missed here. The purpose of a lightning rod, and similar devices, is not to aid in a direct hit. Rods and wire will be fried by a direct hit. The purpose of a lightning rod is to discharge static charge in a radius of the rod. By doing so it greatly reduces the likelihood of a strike in the surrounding area. During a storm, when lightning is likely to hit there is a voltage gradient (build up from the ground) of a few hundred volts per meter of elevation. The lightning rod discharges, or drains, this static charge build-up making it less likely that a strike will occur in that area. A good example of this protection are high-tension power lines. You will always see two small ground wires on either side, near the top. These are static drain wires and they create a curved field over the power lines with a lower static potential than other areas during a storm. This is why, believe it or not, why high tension power towers and lines are rarely hit by lightning. I live on top of a hill, in front of power towers, and we have never had a strike near the house. The hits are to trees hundreds of feet from the house, despite the fact that the power towers are quite a bit higher and metal. Another example is in Florida where tall light poles have an array of smaller wires in the shape of a fan on top of the lights. These wires, pointing upwards are likewise used to drain static fields to greatly reduce the chance of a strike in the area. A strike can hit a light or power line, but it is rare compared to not having ground drain devices.
paul
Well said . I was hoping somebody was going to post that info .
   / Those with lightning storms, how do you protect electronics? #73
I always heard as seen by slow motion video first thing is a dart tracker goes from ground up to the cloud, then lightning follows that back down. The people who survived a lightning strike it couldn't have been a direct hit but one of the secondary ones. My thought is lightning rods work because it's a ground potential up in the air, lightning will strike someplace else. If lightning were to directly hit a rod it would blow it and the wire apart.
I remember seeing a TV show with a video like that. Back in the 80's, my neighbors house 3 doors away from mine, was hit by lightening that traveled up to the clouds. It left a big hole in his roof and all of the debris, drywall, insulation and shingles was blown out and landed in his yard. It even left a hole in the ceiling above the kitchen sink.
   / Those with lightning storms, how do you protect electronics? #74
Were they ok? I hope so. We're having a terrible lightning storm right now...wish my lightning rods were up.
   / Those with lightning storms, how do you protect electronics? #75
Mom, Dad and baby were in the living room, shaken up and a little confused but safe and unhurt.
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55315)
UNVERFERTH 330 8...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59575)
2018 VOLVO VNL...
Sedan (A59231)
Sedan (A59231)
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
