Tiller for 1433
   / Tiller for 1433
Thanks Nasty,
I talked to my MF dealer about getting a weight rack for the tractor. The main problem is that if I put a FEL on later the weight rack has to come off. It would be nice if there were a FEL system that allowed weights when you take the loader off. When I till or bush hog I perfer not to have a bucket sticking out front. I learned the hard way with my old Kubota about misjudging a turn with the bucket sticking out there. Bucket hits tree, tractor stops right now, Mark don't!
   / Tiller for 1433 #12
The FEL for my 1531 came with a brush guard that I'm pretty sure is designed to take suitcase weights. I imagine the weights themselves would interfere with the loader, but the rack obviously doesn't.
   / Tiller for 1433 #13
The front bucket is where I put the rocks that my tiller turns up, then I go dump them off in one place. Every spring there is a new crop.
   / Tiller for 1433 #14
Mark , You are so right about taking the loader off when not needed... Been there and done that bumped a tree or two myself thing :eek: I like driving the tractor without the loader when possible but, must admit in being lazy taking it off when I don't need it....:rolleyes:
Mark
   / Tiller for 1433 #15
You know, I just found this out too on my 1433
I wanted to add a few hundred lbs to the front (the aerator is HEAVY) but they tried and the loader and the weight set don't play together. :(
Not too happy with that, but what can you do.
   / Tiller for 1433 #16
If you have the loader on, put something heavy in the bucket.
   / Tiller for 1433 #17
Jerry is alway coming out with cheap ways of doing things and they work. But Jerry come on spend the guys money ;)
   / Tiller for 1433 #18
Yeah
that works
til you turn, stop suddenly, lower the bucket to move a dirt pile, etc
BTDT, nothing like digging a chain out of a dirt pile cuz I was an idiot.
I like permanent solutions
I still think I could weld a piece of angle iron to the grill guard or something, that would add 50lbs or so.
   / Tiller for 1433 #19
Not saying this is a cheap solution, if your front wheels are drilled for wheel weights, why not get a set of them and bolt them on when using the tiller? I would think cost would be around $150 or so for the set.
I just found this Ballasting Your Tractor for Performance maybe it will help coming up with a solution.
   / Tiller for 1433 #20
I was also thinking of picking up a 5ft tiller for my 1533.... can anyone give a ballpark cost for one of these puppies new? Brand?
Kubota M5-091 (A57148)
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
2019 Hefty 16' Landscape Trailer, VIN: 5NKBU1620KP011139, Tandem Axle, 48" High Steel Cage, GVWR: (A59076)
2019 Hefty 16'...
2244 (A58376)
2244 (A58376)
Kawasaki Mule 2510 4X4 Utility Vehicle (A55853)
Kawasaki Mule 2510...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
