Tiller Question?
/ Tiller Question? #1
mattmayo
Found a used Land Pride tiller ...... 4 foot model in like new condition. What would be a typical asking price for this implement. Seller is advertising for $1000. Is this a good buy?
If not, whats the best 4ft. tiller for the money?
I want to run this tiller behind my JD 2305 tractor.
thanks!
/ Tiller Question? #2
thanks!
I didn't see any info for a 4' tiller from LP. They advertize a 42" and a 50" and if the one you are looking at is in good shape I would buy it. They have a few on TractorHouse.com new for ~$1800.
/ Tiller Question? #3
Depends on if it is a reverse rotation and a slip clutch. I paid $1900 for my new RTR0550 with slip clutch.
King Kutter makes a pretty good tiller and it costs less.
/ Tiller Question? #4
We sell the new Tarter brand made in the USA 48 inch $1495 with slip clutch and 6 tines per rotor and warranty. Ken Sweet
Rotary Tiller
This stout Rotary Tiller will allow you to work the toughest ground with ease. This solid tiller features a cast iron center gearbox that requires a 25-60 HP tractor. The gear driven side gearbox with heavy-duty slip clutch driveline allows this tiller to rip through any type of soil surface. Six self sharpening heat treated tines per flange with adjustable runners makes even the toughest job seem simple. This product is quick-hitch compatible and features our durable, corrosion-resistant powder coat gray finish
Heavy-duty, all gear driven, drive line
Oil bath lubrication
Self sharpening heat treated cutting tines
Adjustable runners
Working depths from 1" to 4"
Category I hookup
Comes with heavy-duty PTO shaft and slip clutch
Easily remove tine shaft
25-60 HP required
/ Tiller Question? #5
Rotary Tiller
Adjustable runners
Category I hookup
25-60 HP required
Ken, that sounds like a well built tiller. Is that a typo on the working depth? Seems a little shallow. I run a Befco and it has a working depth over 8".
/ Tiller Question? #6
Anyone have a pic or schematic showing the innards of the all gear drive, where they replace the chain drive? Appears the all gear is an advantage, but wonder how much and why. Thanks.
/ Tiller Question? #7
I am pretty sure that is a Typo, I have run about what yours does with one of these machines. However, I don't see many tillers do 8 inches in 1 pass until you get into the larger diameter machines. Ken Sweet
/ Tiller Question? #8
The good thing about the King Kutter unit it's buit so the 4Ft unit is offset a little to help cover the tire track on the right side. It is built better then many Italy brands, and priced much lower. The King Kutter brand is probably the US top selling units, so that is why others try to copy it.
I've had vary good success with the King Kutter tiller units.
/ Tiller Question? #9
I agree they don't usually dig down that far in the first pass unless your in pure sand.
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
2011 Nissan Sentra Sedan (A61574)
2011 Nissan Sentra...
Rhino Servis 2160 Ditch Bank Mower (A62180)
Rhino Servis 2160...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
