Tilt cylinder stuck/won't extend
   / Tilt cylinder stuck/won't extend #11
Try switching the lines to the curl cylinders. Does the symptoms switch and will stay extended?
   / Tilt cylinder stuck/won't extend #12
William
Does the hydraulics strain like you are trying to lift to heavy of a load?
Did you try swapping hoses like capt pat suggested from curl to lift lower to see if curl will now operate?
how are you manually extending the cylinders?
   / Tilt cylinder stuck/won't extend #13
Problem happened after reconnecting the loader. I am betting you got some hoses crossed up
2000 INTERNATIONAL 4900 CAR HAULER (A59575)
2000 INTERNATIONAL...
Heavy Duty Solid Steel Skid Steer Mounting Plate (New/Unused) (A59225)
Heavy Duty Solid...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2016 Komatsu PC240 LC-11 Excavator (A59213)
2016 Komatsu PC240...
FUEL CELL (A58216)
FUEL CELL (A58216)
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
