Tilt cylinder stuck/won't extend
   / Tilt cylinder stuck/won't extend #11
Try switching the lines to the curl cylinders. Does the symptoms switch and will stay extended?
   / Tilt cylinder stuck/won't extend #12
William
Does the hydraulics strain like you are trying to lift to heavy of a load?
Did you try swapping hoses like capt pat suggested from curl to lift lower to see if curl will now operate?
how are you manually extending the cylinders?
   / Tilt cylinder stuck/won't extend #13
Problem happened after reconnecting the loader. I am betting you got some hoses crossed up
2012 SOUTHERN VAC 130 BBL STEEL VACUUM TRAILER (A58214)
2012 SOUTHERN VAC...
2020 Freightliner Bucket Truck (A55973)
2020 Freightliner...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
MARATHON 20KW GENERATOR (A58216)
MARATHON 20KW...
2001 Freightliner MB55 Bus (A56858)
2001 Freightliner...
2020 Ford F-150XL (A57148)
2020 Ford F-150XL...
