Tiltmeters-Why Not?
   / Tiltmeters-Why Not? #41
Bird,
I agree with everything you said about the Tiltmeters. And it is why I bought some.
The TIltmeter is a tool, nothing more. How an operator uses a tiltmeter could get them in trouble. Lets say that 20 degrees is the limit for a given tractor. The operator runs the tractor at the angle because its 20 degrees and its safe. But then they hit a small stone which gets them over 20 degrees and they get the Big Rollover. I think a Tiltmeter can be interpreted two ways. Ooops! I'm at 20 degrees I had better do something to get me under 20 degrees. OR, Yeah, I'm at 20 degrees, I'm still good to go. Its the operator's choice. I"ll be in the former group not the later. :cool:
One thing I did notice when I started using the Tiltmeter is that I have a highly edicated tilt meter in the seat of my pants. I can tell pretty much without looking at the Tiltmeter what slope I just bumped through. Course prior to having the Tiltmeter I could only say that was an ok bump or that was a bad bump. I could not say how close I was to 20 degrees. Unfortunetly I did not have a Tiltmeter when I was working on a slope and the seat of my pants told me the angle I hit was really bad. I would really like to know what angle that was but I'm not interested enough to try! :cool:
I'm almost always working on uneven and/or sloping ground. The tiltmeter helps me stay in the safety boundries I have set. A book I bought on a TBN recommendation that is about tracker, FEL, and backhoe operation states that TLB, Tractor Loader Backhoe machines are good up to 30 degrees of tilt. NOT WITH ME ON IT! :cool: Maybe the larger machines can do this but I'm not.....
By the way my fuel guage CAUSED me to run out of fuel the other day. The gauge said I had a quarter of a tank. NOT! I had just backed the tractor up to one of my huge stumps and put the FEL firmly on the ground. I was setting up the backup hoe when the engine said sputter, sputter, stall. 8-( Grrrr.... Course the truck with the fuel is 3/4 of a mile away round trip..... :cool: Off I walk. Get to the truck and I really don't want to move it down the hill so I carry the 5 gallons back to the tractor. Put said fuel in tank. Try to start. Engined starts but then dies.. Try again and again and again Starting to worry about running down the battery. Fittle with the fuel pump. Scratch my head. And end up walking back to the truck to get the manual. Now the JD is supposed to just crank up after running out of fuel. There is no special pump priming procedure like on my truck. I can't find anything in the manual that helps me. Decide I'm not walking back down the hill so I move the truck even though if I get the tractor started and put it in its usuall bedtime spot I'll have to walk back down the hill. :cool: Try one more time and hold the key over in the start position ever after it has cranked over. The engine finally starts and keeps running. YES! By now it is to late to start on the stump so I have nothing to look foward to BUT starting on the stump AND walking back down that hill! :cool:
Later....
Dan McCarty
   / Tiltmeters-Why Not? #42
Hey All! I've been a lurker here for a long, long time. I've come very close several times in the last few years to buying a Kubota, but due to a variety of reasons (usually financial), couldn't swing it. Last Sunday my small green tractor caught fire and now I'm FORCED /w3tcompact/icons/wink.gif to buy one (not that I'm complaining, but now it's a need rather than a want!/w3tcompact/icons/smile.gif)
Anyway, I was trying to decide between the BX2200 and the B2910 (both with FEL and mower decks). Thanks to all the advice here, I decided on going bigger and got a good price on the 2910 from a local dealer and am close to ordering it. Now, however, between this thread and the stupid tractor tricks thread, I'm a bit concerned. My property (9 acres total, 3 acres maintained), has a bit of a slope to it (don't know for sure, but more than 20% in some areas). My concern is that the slope is too great to mow with the B2910. I've checked several locations, but can't find the "maximum lean angle/roll over angle" (I assume it depends on ballast, etc, but is there such a thing?). I never had a problem with the JD 320, but wonder if I will with the 2910 (my great fear at this point is that if I buy it, I'll roll it the first time I mow/w3tcompact/icons/frown.gif). I'm sure I could get by with the BX2200, but really want the 2910! Help!
   / Tiltmeters-Why Not? #43
That's a 20 Degree slope, not a 20 percent slope /w3tcompact/icons/blush.gif
   / Tiltmeters-Why Not? #44
Welcome GFsimon,
Sorry to hear of your Flaming Green Tractor. I don't think you will find a manufactuer/dealer stating that the maximum tilt angle for a a variety of reasons. One reason is that the angle depends on the setup of the tractor and it is very likely to change when using an FEL or backhoe. The position of the FEL/backhoe, its load, will change the center of gravity of the tractor which will have an impact on the roll over angle. The other reason I don't think you will see a roll over angle is the liability issues.
There have been other threads on TBN about how to drive up and down steep slopes. I can't remember where they were but they were in the last six months or so. You might be able to mow the slopes by going up and down instead of across but only you can decide.
Just go SLOW!
Hope this helps....
Dan McCarty
   / Tiltmeters-Why Not? #45
   / Tiltmeters-Why Not? #46
I made one for my tractor.. took a small glass bottle... 2" od or so, and filled half way with a colored like lamp oil.. and the other half with water. Use a permanent marker to make a line arounf the jar where the oild and water meet... I used 2 pieces of masking tape with a space between, as a template for the marker.. then peeled it off after marking.. nice crisp line... looked neat. A god of rtv on the bottom holds it to a flat area on the dash.. but lits it be removable in the furure.
And you have a poor mans artificial horizon...
Soundguy
   / Tiltmeters-Why Not? #47
A beer mug with lines on it works well too. Just make sure it has a lid.
Egon
   / Tiltmeters-Why Not? #48
I have a Tilt Meter and I don't watch it, I notice it. When on a slope I'll glance to it to see what the slope says. One thing I have found out is pucker time don't happen nearly as often. If I had to do it all over again, or if I'd buy another tractor I would make sure I'd equip it with a Tilt Meter.
   / Tiltmeters-Why Not? #49
I have to agree with you and ernie. Let common sense be the judge.
   / Tiltmeters-Why Not? #50
Although, based on (I think it was VON's (the antiques dealer)) picture of what he's mowing, I don't think I'll have a problem!
I remember that thread...he had a picture of the slopes too. However, I believe he went up and down, not across...
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
1989 Hyster H40-XL-MIL 4,000lb Diesel Forklift (A55851)
1989 Hyster...
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
Margaritaville Wall Art (A55853)
Margaritaville...
2018 Chevrolet Camaro 1LT Coupe (A55853)
2018 Chevrolet...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
