Ha!!!schmism said:those are just weeee pebbles! 3/4" SDS drill Fethers and wedges (or cordite? the expanding material you pour down in the holes) big rockes ----> little stones
No question that would be a lot of fun... but as a practical matter, the trees have no place to fall without potentially damaging a building or other trees that are staying. Also, I am not insured for tree removal unless it is already on the ground or small enough to be pushed down by my own tractor.lug nut said:If the trees are gonna have to come down too, I would go for the track hoe. If for nothing else but the cool factor of knocking down some trees and digging up some rocks with a huge toy.![]()
Dougster said:Ha!!!Great idea... but client is not going to go for that if the rocks can be pulled or pushed 20 feet out of the way. This property has huge rocks all over it everywhere. Moving rather than removing makes the most sense here. I'm just trying to figure out what equipment will do it best!
Dougster
Hi Alan - The client doesn't really care whether his property contains 1,619 very large rocks or 1,617 very large rocks... it's all the same to him.AlanB said:I guess I am missing something here, does the client want to use the rocks somewhere else? I have not done it per se, but I would think in 4 hours work, I could split those rocks down to a size to work with your equipment. It would take me more then 4 hours to get the rental stuff worked out and on site. So long is it was ok if they were smaller, that would probably be my approach. Can you say BIG hammerdrill![]()
Thanks Alan. I'll do some further investigation into this possibility. Never had a need to do this sort of thing before... but now every third job seems to involve some solid or large rock removal-related work. I bought a jackhammer for breaking up concrete and asphalt... but have nothing appropriate for solid rock. Apparently drilling and splitting is much preferred over hammering (even with a high-flow skidsteer and quick attach hammer)... so I'll investigate what it would take me to go that route without having to use a costly specialty subcontractor.AlanB said:But the short version is, split those rocks into littler rocks then move them with what you have. Or maybe, drill the fault line, then rent a bobcat with a hammer and use it to exaggerate the fault and split the rock. If it was me, it would be a trip to HF for a BIG hammer drill, and some long bits. Or, You could also saw cut it with a diamond or abrasive blade, then sheet it off. You may end up doing this no matter what (as may the guy that said dozer) when you find that rock goes 15' underground....![]()
Only when I tickle them!AlanB said:Do they "wiggle" at all?
