tire rims
   / tire rims #12
I have an Iseki TA207. I had Hey Machinery make a set of wide rims for it. I put industrial tires on them. He can take rims and make centers to any bolt pattern and offset you want. They aren't cheap, but they are very heavy duty.
785-594-3441
   / tire rims #13
Yes, it seems that a lot of the small diesel tractor rims can be interchanged. I don't know all the models that can cross, but there are some.
   / tire rims #14
I found the picture where it looks like they put trailer rims on the front of the tractor.
   / tire rims #15
The Hoye tractor site got back to me and they said they also can make any bolt pattern I want. They seem to be another good source. Now I just need to confirm what bolt pattern I have on my Bolens G154 (Iseki TX2140F). These are hard to measure but I think they are:
Where d=bolt hole diameter, D=large hub opening diameter, I=diameter of circle bolt holes fall on.
Front D=70mm. I=100mm d=13mm. 4 bolt
Rear D=90mm I=120mm d=13mm. 6 bolt
   / tire rims #17
I learned a hard lesson this week. I had my front tires loaded, I don't have an FEL, and I use a dirt scoop, so I need at the weight I can get on the front. I used my impact wrench, on my original OEM rims, that came on the tractors, and I cracked them all the way around the bolts. I brought it to have it welded, and they looked at it, and said that it was not worth the money, and would be difficult to weld. I searched very hard for a new rim,a nd the only one I could come up with is one from Yenebiz, and the shipping anlone is over $200 from Europe. I did alot more research, and finally I found that the rime from a Kubota B7100, B6100, B5100 will fit perfectly, and the rims runs around $100. I had the dealer measure it, and it is a perfect match, and it even has the wheel weight holes that match up the same. I think that the rims are made by the same company in Japan for both Iseki and Kubota. I just need to paint it white when it gets here, and have the tire remounted. The part number for the tire is, 70000-00024. This site has it for $115, but I ordered it from a dealer because I wanted it to match exactly, and this rim has gaps on the inside. Anyways, i thought that you guys may be interested who have been looking for front rims. This is for the 5.00 by 12 rim size.
Kubota 5X12 Front Wheel
Mitch
   / tire rims #18
Thanks for the link. Those rims are very difficult to find. I thought I found some for $70/ea (from one of the threads here - maybe even this one). When I got the two I ordered I opened the box and everything appeared like they were the ones I needed (4 bolt holes, 5-12, etc.) After closer inspection they are for a TS1910 or something like that so all the hole patterns are too large but it wasn't obviously different from initial inspection. Kind of a bummer. I decided not to send them back but instead I'm hoping modify them some day with the help of a lathe and some welding/recutting. I think it can be done but that will be down the road sometime.
Don't throw away your old rims. I'd pay you shipping + something for your time if you're going to do that.
   / tire rims #19
I also have a G152 and have looked for rear tires and found none, also the last time I tried to call Sam's bolens, last month the phone numbers were both out of order.
   / tire rims #20
My new front rim came in today for my Bolens G154. It is a Kubota 70000-00024, and it is a perfect match. I think that it is the exact same rim as the OEM rim. Perfect fit. You can see the self inflicted damage I did to my old rim by over tightening the bolts with an impact wrench. Costly mistake. The rim was about $120.00 plus shipping to give you an idea. I wanted an OEM rim, but this is the same thing, just orange. Now to paint it white, and have it reloaded and mounted. Otherwise the tractor would look like a Bobcat tractor. Not that this would be a bad thing, I like their tractors, but its a Bolens, so, anyways, I thought you guys who were looking for rims might be interested.
Mitch
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A56857)
2025 Kivel Fork...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56435)
2017 Yale GLC050VX...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A56857)
2017 Kawasaki Mule...
White Metal Roof Panels (A55758)
White Metal Roof...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
