Forks Titan Attachments Pallet Forks MIA
   / Titan Attachments Pallet Forks MIA #21
Try contacting Fedex about returning the frame on their dime. Worth a shot. Probably good to make sure you will get you $$ returned from Titan though if they get the frame back.
   / Titan Attachments Pallet Forks MIA #22
save the backing that you received and make something else out of it.
add a hay spear to move hay.
make a cage man lift.
brush hauler
   / Titan Attachments Pallet Forks MIA #23
brush hauler
I would consider buying it, if I knew where he was. I do miss having forks.
   / Titan Attachments Pallet Forks MIA #24
I bought these forks from them (palletforks.com - I think that's the same company) three years ago and I have zero complaints. They're on my loader probably 60% of the time, and I've abused them digging boulders out of the ground (probably shouldn't do this) and have had nothing happen. I don't recall packaging concerns; mine came all on the same day, though I can't remember if the cling wrap was marred or not. They could be easier to move from one setting to the next (raise loader arms a bit, drop curl to about 45 degrees, and it's a lot easier... but still not slippery smooth) but they seem super solid to me.
   / Titan Attachments Pallet Forks MIA #25
Yep - same here. Good company with free shipping. Ordered stump bucket, Maintenance cage, 8 ft scrape blade, forks 40 inch and 60 inch and landscape rake. Have been pleased with all. Free shipping on heavy items makes their products affordable.
   / Titan Attachments Pallet Forks MIA #26
I have the same set of forks. When they were in shipment I got a phone call from FedEx asking if I wanted them to be delivered as the packaging had been damaged. Luckily everything was there, although I believe that I had to buy a couple of pins.
If you do end up with a complete set be aware that the backing plate isn't much better than tin foil. I haven't decided if I'm going to buy a heavier plate or an entirely new set of quality forks. In hindsight I wish I'd put the money toward the grapple I eventually purchased, and bought a decent set of forks later.
My EA forks are great, and not any more expensive than other quality forks.
EA will no longer ship to Maine though, so you would have to pick up in NH.
   / Titan Attachments Pallet Forks MIA #27
Titan is palletforks. I get my flush faced connectors from them.
I've decided just to wait for the replacement forks. I may have mentioned that I would have to pay shipping for the return. That was incorrect and a misunderstanding on my part. Titan Attachments (palletforks.com) would have the rack picked up and I would get a full refund. I called around today looking for any SSQA pallet forks and there's just NOTHING out there. I was talking with my buddies today and you're starting to see the real effects of this country being shutdown and locked down as long as it was. I'm considering spending a couple of hundred dollars just to make sure I have a good supply of spare parts for my tractor. When stuff goes out of stock, you just don't know when you will find it again. I ordered a Piranha toothbar from BX Expanded a month ago and they just told me it will likely be another month before it's shipped.
   / Titan Attachments Pallet Forks MIA #30
It's not just this country. It is all the countries that supply this country.
If you have a recent model tractor or car, don't expect to get electronic control modules. Lead time on some automotive chips are being scheduled at 92 weeks. I have parts that I need for our production scheduled out at 92 weeks... How do you run a business with that kind of lead times...
Let's be careful not to take this off topic. Steel is precious like wood is precious right now. Prices are nuts if you can get some. The items you are looking to buy likely need precious steel.
2014 Wacker Neuson BS50-4s Jumping Jack Plate Compactor (A55851)
2014 Wacker Neuson...
2019 Nissan Versa Sedan (A55853)
2019 Nissan Versa...
2003 Chevrolet 1500 Silverado Crew Cab Pick-up Truck (A55852)
2003 Chevrolet...
2014 Toro Workman HD 07369 Utility Cart (A55851)
2014 Toro Workman...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
1998 MACK CH613 DAYCAB WINCH TRUCK (A55745)
1998 MACK CH613...
