TN70A won't start?
   / TN70A won't start?
LoneCowboy said:
the powershift shuttle lever (left hand) is in neutral. (and the switch also thinks it's in neutral)
did you check fuses?
Just finished checking the fuses (one by one) all are good!
All levers in neutral.
Still just a single "click" when key is turned to start position. The click is in the same area as the key ( on the left side).
No other noise or activity.
Next step VOM!
Bob
Wildcat Ranch said:
Maybe unscrew the dash cover and make sure all the wires are connected to the key switch?
Will start unscrewing!
Bob
   / TN70A won't start? #13
Sounds like the key switch, if it's anything like the smaller frame tractors'. No lights are dimming when you turn to start, means no current going to any device. We'll know soon, no doubt...
good luck, Jim
   / TN70A won't start? #14
Place volt meter on starter solenoid and turn key to start; should see 12 volts when key is turned to start. If you have 12 volts; time to check starter. If no voltage present; time to back track to ignition switch and see if you have voltage coming in/out of ignition switch. You may have a defective relay.
Thanks for helping me.
Bob
good luck, Jim
yes, we will know soon. Thanks, Bob
   / TN70A won't start? #17
Doc, try just tapping on the starter. Sometimes they land on a place which can't get current to it. Old trick, but sometimes it works.
Loose wire on the starter solenoid!!!!!!!!!!!!!!!!!!!!!!
Starts like a champ!
Thanks to everyone here for their kind advice and support.
Bob
   / TN70A won't start? #19
Glad to hear it was found and was easy to fix.
   / TN70A won't start? #20
Its always nice when its a easy fix and even nicer when you don't have to shell any money to do it!
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
2020 CATERPILLAR 246D3 SKID STEER (A60429)
2020 CATERPILLAR...
13042tx (A55973)
13042tx (A55973)
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
2018 Chevrolet Tahoe SUV (A59231)
2018 Chevrolet...
2009 Ford E-450 Ambulance (A55852)
2009 Ford E-450...
