To rebuild or move on
   / To rebuild or move on
The parts and having all the cylinders rebuilt totaled a shade under $10k. Worst part of the deal is the front dif and the leak in the bottem. That accouts for almost $3k of the job. Nothings cheap in NJ
   / To rebuild or move on #12
Got any pics to show what you are talking about? Always helps people understand what you are seeing and make some better recommendations. I know I'm curious to see it...
   / To rebuild or move on #13
I missed the part of all the cylinders needing to be rebuilt. That is probably about $2000-$2500 right there for all 11 cylinders. I can see the transmission leak being about $2000. Is it just one bevel case, or axle seal or both, that are leaking. I can see that being as much as $400 a side. All of the hoses? If they are building them themselves and installing them another $1200, 50-100% more if they are using factory hoses. Complete wiring harness and installation maybe $800-$1000, a couple hundred for the headlights. The steering column leak another $200. $500 for fluid and filters. That is about $8000-$9000 so I guess it could all add up to $10,000. You really let that thing go to **** before fixing it. That machine would be like new afterwards. To me $10K for a like new machine beats $23K for a machine that you know nothing about. If it is in this bad of shape I think you will have a hard time getting $8000 for it. That is a lot of oil leaks to hide.
Brian
   / To rebuild or move on #14
Beautiful car. This will probably make you ill, but my Dad and Granddad took apart a 29 chevy sometme in the 30's to use the engine in a home made sprayer.
Never had to do much to the Kubotas. That's why I love them. I had to replace the bucket cylinders on the 3430 due to a bit of misfortune. I found those at Baileys for less than 20% of the dealer price.
I collect and work on old fire trucks. I presently have a 53 IH and a 52 Mack. The IH is for sale and I'm just starting on the Mack. I don't totally restore them, but rather I work to bring them back to original condition. I.e in the case of the IH it has original paint, that while not perfect, I prefer because it is original.
Given that the tractor is for work, even though working the tractor is rarely WORK, I'd be inclined to get something newer that I knew I could depend on. If the fire truck leaves me stranded I get it towed home, but if the tractor quits in the middle of a snow storm its a crisis. Plus I'd rather be working the tractor than working on the tractor.
Brian
She runs like a top digs like a groundhog and plows snow like a tank. All the leaks are very slow more of a pride thing then an issue. Since i have had this machine its been garage kept and washed and waxed often. Yes i wax the hood and fenders. I could rebuild it in stages and do it slowly over the next year. Its hard to think about it not being in the garage but then i think about biggef and i wonder. Wish i could have both!
   / To rebuild or move on #16
I would address the problems one at a time - over a time - that way your spread the cost and it does not hurt that much. Also, I would do it myself as much as possible, but that's just me.
   / To rebuild or move on #17
B20 IS the rebuildable machine. plenty of new and used stuff out there.
BUT... sometimes newer models have more options and power.
tuff call.
budget will make your decision.
Massey Ferguson 8200 Flex Platform (A59814)
Massey Ferguson...
Ryan Walk Behind Aerator (A59228)
Ryan Walk Behind...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
2014 Ford F-550 (A55973)
2014 Ford F-550...
2001 Workhorse Custom Chassis P42 Delivery Truck (A59230)
2001 Workhorse...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
