To Yield or Not
/ To Yield or Not #1
jlgurr
Veteran Member
Bostic, NC
Massey Ferguson GC1705, John Deere STX46
I think this is the most appropriate forum because if we weren't rural there would be a traffic signaling light here instead of the mess I found today. Actually curious on two counts, first is if anyone else seen this scenario of traffic flow and signage and second, what is the lawful way to navigate the situation I faced today.
Referencing the attached image:
No traffic signals, only signs. The primary road is running left to right here and the top to bottom is actually the entrance to a local strip mall. Traffic leaving the mall approaches the main road with a stop sign. On the road everything appears normal to the birds eye. When a driver approaches the intersection from the right side of the image S/he can turn right into the mall drive or proceed straight through without stopping. From the left approach a driver must indicate and complete left turn to enter the mall entrance. Other traffic approaching from the left may proceed straight through the intersection without stopping (No signal lights.)
Sounds simple doesn't it. Ok, now the exception. Driver approaching from the right wants to make a right turn into the mall. S/He has a YIELD sign and an approaching driver with a left turn signal blinking. Which driver is expected to yield the right of way? What were you taught? Have you ever seen this silliness before?
So what happened today is the second vehicle turned left into my path which I thought was my right of way. When I confronted her she said the Yield sign on my side of the intersection gives HER the right of way. But I thought left hand turns always yielded to oncoming traffic except in the case of left turn green arrow. What gives?
/ To Yield or Not #2
she's right. if there's a yield sign then you should yield.
/ To Yield or Not #3
That is a bit odd, but given that there is only one flow you'd ever be yielding to -- people coming from the other way turning left -- I'd assume the yield sign is there to mean they have the right of way. There is nobody else to ever yield to.
Maybe has something to do with the fact that they already split up the road coming from the right into a main (straight) lane and that right-turn lane. Not quite a traditional intersection where the normal rules of right-of-way are simple (in which case you would have been correct).
/ To Yield or Not #4
You yield. At that point you are no longer turning right, you are merging left into a traffic lane, which she is already in.
/ To Yield or Not #5
We have many of those situations here in Alabama. Every entrance onto the Interstate has a YIELD sign for the people turning right onto the entry lane while the people comming from the other direction turmimng left has the right-of-way. And you will get a ticket if you don't yield and my wife will yell at me if I don't.
/ To Yield or Not
More than half the people I've polled here at work agree that it's odd and a few who live nearby have stated it's an area with high frequency of accidents. Go figure. The other oddity is that from "her" direction there is no indication whatsoever that the left turn has the right of way to that person who is approaching and turning right. So, she must be local also and knew the yield sign was there. But I'll tell you if I was in her position waiting to turn left there is no way I would assume the person over there is going to yield to my left turn even if I knew there was a yield sign for them. As a matter of fact this is the first time I've seen a person do what she did at that intersection and I have never seen a driver yield as she expected me to.
It just doesn't make sense to me why this intersection would be that way. Seems to be creating more hazard than addressing any improvements in flow.
/ To Yield or Not
Now that you mention that, I too have seen them often on interstate ramps intersecting secondary roads, but it is always in conjunction with a signal light and seems to be a reminder that those making left turns have a green turn arrow giving them a right of way.
/ To Yield or Not
That would make more sense to me if her and I were not joining that entrance from the very same road. Meaning if my approach lane was fuurther up in the image and she had already been traveling in the axis of the new road.
/ To Yield or Not #9
These kinds of turns are very common around here. It's basically a miniature version of an on-ramp... people on the on-ramp yield to traffic already in the travel lane. The fact that in your case that she turned into the travel lane only 1-2 car lengths ahead of your merge doesn't change that basic rule.
/ To Yield or Not #10
Out here in rual Alabama, there are NO signals, just a lot of yield signs.
/ To Yield or Not #11
i bet the thinking is they want left turns into the shopping center to flow thru and not encounter a stoppage or backup into oncoming traffic.
we have an intersection here that's the same way, but there is limited traffic that makes that left turn, compared to the traffic turning right
onto this particular road.
/ To Yield or Not
Looks like I'll be hunting me a big crow this evening. :licking:
/ To Yield or Not #14
Looks to me like there should a much better/safer way to design that interchange. I've NEVER seen anything like it and, thank goodness, have nothing like that around here.
/ To Yield or Not #15
I agree with you there -- if I was coming from the left, how would I know people in the other direction were yielding? If there was a green left turn arrow, that would be one thing (that's pretty much an unconditional left turn) but there isn't.
/ To Yield or Not #16
Its really not all that bad. You just need some small speed differential at the merge point and go in front or behind ... whichever is smoothest for the specific instance. Sometimes, with several coming from the left youll have to stop. Plenty of visibility.
/ To Yield or Not #17
On almost every "On" ramp... With me making a left onto a ramp; if the only on coming vehicle is in the turn lane to also get onto the ramp. They have to yield.
{EDIT} Went back and read the other posts, guess I'm late to the party... duh!
/ To Yield or Not
Yep, I have seen this at ramps and intersections of interstates with secondary roads also. This is the first I've come across one between two roads as such. Also, she was rather presumptuous that I would be yielding given the fact in her direction there are no signs indicating to her that my lane would yield. As I mentioned before, if it were reversed and I was making the left turn then I'd not take the right of way, for that reason.
Sent from my iPhone using TractorByNet
/ To Yield or Not #19
It would be common courtesy for both vehicles to adjust to allow the smoothest traffic flow. But even if you didn't have the yield sign, the vehicle turning left would have the right of way.
/ To Yield or Not
Sorry Randy, I completely disagree with that statement. That would imply a driver would need to yield every time he approaches a vehicle with a left turn signal on. And what if the oncoming driver was not using their signal, which is more common than ever. Does that mean I should stop just because it appears they 'might' make a left turn in front of me. Yeah, that would really honk off the drivers behind me.
