Today's stupid question: re ballast box
   / Today's stupid question: re ballast box #1
grahamu
BC, Canada
Kubota B7800
Today\'s stupid question: re ballast box
You see, this is the problem with everyone being so helpful; I just keep asking more and more questions /forums/images/graemlins/wink.gif
Having mastered (not) the art of using my rotary cutter after 5 hours in the seat I decided it wa stime to tackle my FEL.
I successfully removed the cutter from the 3PH and went to connect up the ballast box.
Since the lower arms didn't reach down to the ground I actually had to lift the box while I connecetd it up; no problem since it is currently empty but it will be a different story once I get it loaded.
So my question is; how do I then unattach and subsequently reattach a fully loaded ballast box? The only thing I can think of is that I will need to have something 9-12 inches high to stand it on when it is not on the tractor. Am I missing something (quite possibly)?
Thanks,
Graham
Thanks,
Graham
   / Today's stupid question: re ballast box #3
Re: Today\'s stupid question: re ballast box
I think you have it figured out pretty good. That's what I would do. Good luck. /forums/images/graemlins/smile.gif
   / Today's stupid question: re ballast box #4
   / Today's stupid question: re ballast box #5
I made a dolly for mine (attached picture). If you have a cement floor it works great and it is easy to make.
John
   / Today's stupid question: re ballast box #6
John
   / Today's stupid question: re ballast box #7
And in the future when you get a welder to do more projects you can change the height of the ballast box attach points so you won't need a stand to set it on.
   / Today's stupid question: re ballast box #8
   / Today's stupid question: re ballast box #9
Wow, I'd like to see a picture of that?? Why would they build a ballast box that you can't sit down??? I don't understand???
   / Today's stupid question: re ballast box #10
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
(10) 2 PLUG VALVES (A52472)
(10) 2 PLUG VALVES...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
SHOP MADE MANIFOLD TRAILER (A52472)
SHOP MADE MANIFOLD...
20" Sea Container (A47384)
20" Sea Container...
