Today's stupid question: re ballast box
   / Today's stupid question: re ballast box #1
grahamu
BC, Canada
Kubota B7800
Today\'s stupid question: re ballast box
You see, this is the problem with everyone being so helpful; I just keep asking more and more questions /forums/images/graemlins/wink.gif
Having mastered (not) the art of using my rotary cutter after 5 hours in the seat I decided it wa stime to tackle my FEL.
I successfully removed the cutter from the 3PH and went to connect up the ballast box.
Since the lower arms didn't reach down to the ground I actually had to lift the box while I connecetd it up; no problem since it is currently empty but it will be a different story once I get it loaded.
So my question is; how do I then unattach and subsequently reattach a fully loaded ballast box? The only thing I can think of is that I will need to have something 9-12 inches high to stand it on when it is not on the tractor. Am I missing something (quite possibly)?
Thanks,
Graham
Thanks,
Graham
   / Today's stupid question: re ballast box #3
Re: Today\'s stupid question: re ballast box
I think you have it figured out pretty good. That's what I would do. Good luck. /forums/images/graemlins/smile.gif
   / Today's stupid question: re ballast box #4
   / Today's stupid question: re ballast box #5
I made a dolly for mine (attached picture). If you have a cement floor it works great and it is easy to make.
John
   / Today's stupid question: re ballast box #6
John
   / Today's stupid question: re ballast box #7
And in the future when you get a welder to do more projects you can change the height of the ballast box attach points so you won't need a stand to set it on.
   / Today's stupid question: re ballast box #8
   / Today's stupid question: re ballast box #9
Wow, I'd like to see a picture of that?? Why would they build a ballast box that you can't sit down??? I don't understand???
   / Today's stupid question: re ballast box #10
2009 Lee-Boy 8510HD Conveyer Feed paver (A52748)
2009 Lee-Boy...
1986 Value 40' Drop Deck (A50121)
1986 Value 40'...
Hydraulic Spray Boom (A50121)
Hydraulic Spray...
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
1994 Prevost Liberty Coach Motorhome (A51694)
1994 Prevost...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
