Too much power on my new impact!
   / Too much power on my new impact! #31
Grind/file head of bolt as flat as possible. Center punch the bolt. Use a small ( 1/4" drill bit and drill it either all the way thru or as deep as you feel comfortable. Then use a bigger size LEFT HAND twist drill; it should back out easily. Easy outs usually break. Using right hand twist first helps torque the threads in one direction and when using the left hand drills the bolt should come out. If impact did not back it out, it is tight; use penetrating oil while drilling.
   / Too much power on my new impact! #32
Last night on "MegaTools" on the History Channel, they mentioned "the largest impact wrench ever made; the Ingersoll-Rand model 559, so named because that's how much it weighs!!" Guess that one would either easily back the bolt our, or just as easily twist it right off!
   / Too much power on my new impact! #33
Hmm - Guess I have been lucky as I have never had an EZ out break and have used them more than a few times.
   / Too much power on my new impact! #34
Oh, yes, they are quite fun to get out when broken ... trying to aneal them before drilling is my favorite part :(
   / Too much power on my new impact! #35
Homebrew - I don't understand
Why would you try to harden the EZ out before you drill it out?
   / Too much power on my new impact! #36
Anealing "softens" the already hardened ezout, so it can be drilled out with a standard high speed steel drill [bit].
   / Too much power on my new impact! #37
That's what they make cobalt and carbide drill bit's for. I don't think I even own HSS drill bit's anymore. All of mine are at least cobalt.
   / Too much power on my new impact! #38
Got it - I thought anneal meant just the opposite - to toughen or harden
   / Too much power on my new impact! #39
I'm not sure how far away rubber seals are from the busted bolt, but when all else fails a little heat often seems to work for me. If you could heat the bolt to red and get a vice grip on it, it might just come right out!
   / Too much power on my new impact! #40
Of course, you're right. This thread would be a great opportunity for you to demonstrate, or dictate the steps for, drilling out an ezout with a cobalt-steel drill [bit] ... or carbide, if you prefer ...
MISC WRENCHES (A53843)
2019 CHEETAH T/A CHASSIS TRAILER (A53843)
2019 CHEETAH T/A...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
2019 ALLMAND NIGHT-LIFE V SERIES LIGHT PLANT (A52706)
2019 ALLMAND...
Auger for mini skid steer (A53421)
Auger for mini...
PAIR OF 607 CHALLENGER PUMPS (A53843)
PAIR OF 607...
