Tooth Bar Teeth
/ Tooth Bar Teeth #1
dixy1dog
Northern West Virginia
BX 2230
Hey,just wondering if anyone knows of a place that sells teeth for a Tooth Bar.I have a BX2230 and wanted to make a tooth bar. All the ones I've found so far are for the big Cats and such.Thanks Dixy1dog
/ Tooth Bar Teeth #2
Do a search in the Build it Forum. I want to build one also, and a guy posted recently how he built one.
ron
/ Tooth Bar Teeth #3
Call Carver...they sell Woods Toothbars, but they sell the teeth too.
Not expensive...less then 10 bucks each.
/ Tooth Bar Teeth #5
I got my teeth from Fabco, Inc.
/ Tooth Bar Teeth #6
Fabco, inexpensive.
Hensley, expensive.
E-bay, inexpensive, search for bucket teeth.
You will need both teeth and mating shanks if you intend to build your own toothbar.
Pic's please if/when you get going.
Add up all the costs and then check out Markham. You may be surprised how competitive they can be vs make your own.
All the best,
Martin
/ Tooth Bar Teeth #7
Going with the Markham tooth bar from Antietam, along with the purchase of the NH TC48DA was the best deal for me. By the time I added up the cost and time involved to purchase the items, pay for shipping, or pick up. Markham already has the beveled cutting edge that matched up perfectly with my bucket. I basically calculated that I payed for several hours of professional welding, with a high quality wire spooled, inert gas welder, and a highly skilled welder, who's been welding Markham tooth bars, and knows every in and out of tooth shank attachment welds. I have built my own in the past with stick welding, but the Markham bar was too sweet to pass up on. It almost falls off when you want to remove it. Warning, these Markham toothbars in 72" length are heavy. The bar stock which the 2.25" wide teeth shanks are welded to is 3/4" x 4". Very stout and designed for heavy use. /forums/images/graemlins/smile.gif
/ Tooth Bar Teeth #8
Post a site for the teeth manufacturer FABCO, INC. I did a search and come up with all sort of FABCO's. One built food machinery and didn't look like they would know about toothbar teeth. bjr
/ Tooth Bar Teeth #9
<font color="blue"> Post a site for the teeth manufacturer FABCO, INC. </font>
Here you go.
FABCO
/ Tooth Bar Teeth #10
I wonder how you attach "crimp-on teeth"? bjr
/ Tooth Bar Teeth #11
bjr,
The ones I use have male dimples on the sides. They fit into recessed dimples on the shank and you tap them into the dimples. Look closely at the teeth in this picture and you can see the dimple on the side of the teeth. (sorry, no close up)
/ Tooth Bar Teeth #12
3RRL, Did you make that tooth bar? I have the same tractor with a Koyker 195 loader and I am interested in which shank and tooth you purchased and where you purchased them.
2012 Volkswagen Jetta Sedan (A61569)
2012 Volkswagen...
LandHonor LHR-UBF10 10in Utility Blower Fan (A60352)
LandHonor...
New/Unused SD Lanch Mobile Crusher (A61166)
New/Unused SD...
(2) Two Ton Jacks (A62177)
(2) Two Ton Jacks...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
