Tooth Bar
/ Tooth Bar #1
strez
Southern Tier, NY
New Holland TC30 HST 4WD
What do you think of this?
I'm considering purchasing one, but would like some opinions before pulling the trigger. Seems like a reasonable price @ $160. Thanks!
/ Tooth Bar #2
I paid almost $300 for a 61" WOODS toothbar...
/ Tooth Bar #3
Hi Jeff...
So are you going to be the TBN test pilot and buy one of these bargains...? /forums/images/graemlins/smile.gif
/ Tooth Bar #4
I saw the same auction on ebay and ended up emailing a gentleman by the name of Gary. I liked what I saw and have pulled the trigger. I'll let you guys know how it works out.
Apx. $185.00 with shipping.
Joe
/ Tooth Bar #5
I paid the same for the same size FFC through KC Canary. While I like the style of mine better, I'm not sure I like it $100 better. /forums/images/graemlins/smile.gif
This one looks great if you're going to leave it on all the time. It seems to have more teeth per foot than mine, too. Good luck with it.
/ Tooth Bar #6
I payed 300 dollars for my tooth bar for my bx22. IT has replaceable teeth does this tooth bar have replaceable teeth if one gets chipped ob broken how will you fix it ? I like my tooth bar it is well constructed easy to install and remove with two bolts. good luck David
/ Tooth Bar #7
david43a:
Did the bolts mount up to existing holes? Or did you have to do some drilling into the loader?
Thanks,
Joe
/ Tooth Bar #8
Personally, I don't like it much.
My toothbar is held on with two bolts. Goes on and off in a couple minutes. There are times when you don't want the tooth bar on. It would be a pain to take one off that has that many bolts. I would also imagine that the nuts/threads on the bottom might get dinged up and that would make matters worse if you wanted to take it off.
The one I got slips over the bottom lip, totally covering the lip on the top and bottom, and has replacable teeth as well. It is very strong. It did cost almost double the one that is on ebay though. But I think it is money well spent. Yesterday it helped move about 100 tons of fill, dirt with some broken concrete in it...
Here is a pic of a toothbar at work. I posted it here somewhere else, but forget where at the moment...
A well made toothbar is probably worth $300 in my opinion. Glad I bought a good one! Money well spent...
/ Tooth Bar #9
I'm in the market for a tooth bar myself and that looks good for the price. The difference that I see is like Henro mentioned........most slip over the lip of the bucket. That and all the bolts on removal. But then again, $100 cheaper sounds good too /forums/images/graemlins/grin.gif
Looks like he's sold a bunch of them on Ebay.........wonder how the users like them?
/ Tooth Bar #10
</font><font color="blue" class="small">( What do you think of this? )</font>
I think that if that design was without significant problems, the major manufacturers would be offering theirs built that way. As far as I know, they aren't.
SnowRidge
/ Tooth Bar #11
I'm sure it WORKS just fine. But all those mounting bolts are silly when there is an alternative. And the non replaceable teeth (looks like) doesn't make much sense either. But then most folks will probably never wear down the originals...
/ Tooth Bar #12
<font color="blue">...all those mounting bolts are silly when there is an alternative. And the non replaceable teeth (looks like) doesn't make much sense either... </font>
The teeth that are being used... DON'T SLIP OVER THE BUCKET'S CUTTING EDGE... (in essence clamping itself to the bucket), therefore he has to use all those holes/bolts to secure the assembly...
I agree... it's probably a "cost factor" on why this builder uses these non-replaceable/non-standard teeth, instead of what is commonly used on the $300. + toothbars...
If this builder goes to the "normal" teeth, and uses a 2-bolt approach for securing, and then sells it for $160... Then he'd be cooking....! /forums/images/graemlins/wink.gif
/ Tooth Bar #13
I don't think most users will be thrilled with the idea of drilling a couple dozen holes in the bottom of their buckets, especially if they take their tooth bar on and off as I do. Personally, I think I'm happier with mine for the extra $100 and the twenty fewer holes. /forums/images/graemlins/smile.gif
/ Tooth Bar
Thanks everyone for your opinions. I've decised to pass on this tooth bar and get one that has replaceable teeth, slips over the front edge of the bucket, and is held im place by two bolts, one on either end. I'll pay a bit more, but probably be happier in the long run. Thanks again.
/ Tooth Bar #15
I'd like to second the those sentiments by Jeff. You guys haven't steered me wrong yet. I never even thought of the bolts being such a hastle let alone drilling all the holes. The removal as suggested above is also a concern, particularly if your picking up the stuff Henro shows off in his picture. I'm cancelling my order.
Joe
/ Tooth Bar #16
I would have to agree. When you break one of those teeth off you might as well throw the toothbar out. It would take a while to drill all those holes in a bucket. I would pay the extra for a better toothbar. It will be worth it in the long run.
/ Tooth Bar #17
As always, a good discussion that raises a bunch of relevant issues to mull over. I have decided, based on previous posts, to buy some forged combine guards, which are basically 6" long "tooth pairs", $6 each at TSC, and weld them to a strap of 3/8" steel, which I will bolt to the lip with maybe 3 or 4 elevator-style bolts. I hope to do all this for about $50-60 total (figuring 0 for the welding). Since I have a special purpose- busting up ground-up asphalt road material piles, it oughta work. But the discussion is great! Hope to post a photo when I get it on the bucket.
/ Tooth Bar #18
The teeth on this tooth bar are not a whole lot different than the shanks on the small back hoes. About the only difference is that they don't have the pin on teeth to cover the shank. The shanks on the small backhoes will bend and will break off. When they do, you just weld them back on or replace them if they are bent to much.
/ Tooth Bar #19
Ok........I just ordered my toothbar today. But it is the type that slips over the cutting edge. I think I'll be happier with that one. 54" for $270+/- a buck or two. with shipping and tax. I could have had it delivered here to the house, but the dealer is a member here and I want to meet him, so I'll go to his shop and get it. Besides maybe I can talk him out of a hat or T-shirt /forums/images/graemlins/grin.gif
Jerry
/ Tooth Bar #20
It is more common on some skid steers to have a bolt-on cutting edge. Then you replace the cutting edge with this bolt on tooth bar. I'd buy it in a second if I had that type of bucket.
As others stated, it's kind of a mess if you don't already have the holes drilled, & wish to mount/ dismount it often.
As to the sickle guards, they are mallable cast iron ( designed to be bent with a hammer) and probably will not last very long at all at a dirt/ tar/ rock worker. Might do the one job fine that the person has in mind with the tar, but do not plan on a long-lasting item. Just a heads up to others thinking of it.
--->Paul
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
2012 Chevrolet Camaro Coupe (A59231)
2012 Chevrolet...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2014 REITNOUER MAXIMISER 48' FLATBED TRAILER (A59905)
2014 REITNOUER...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
