Top 10 things NOT to do with a new loader!
   / Top 10 things NOT to do with a new loader! #101
Roadhawk's is a keeper.
Jim
   / Top 10 things NOT to do with a new loader! #102
Watch the clothes line! No riders in the bucket. Don't walk under the bucket when raised. Always park tractor with bucket on ground.
Thanks.....Casey
   / Top 10 things NOT to do with a new loader! #103
Don't chain up a full length tree to the bucket and then try to pull it while backing up a hill. This is especially true with a 4WD tractor. This might seem like a handy way to skid a tree since you can lift the end of the log so very easily...
I was quite proud of my new mighty tractor and what I thought was a good idea until....
I thought it odd that the hill was getting steeper than I remembered. Just then I discovered that the bucket was going down while the rear wheels of the tractor where lifting well off the ground.
Footnote to self.. "don't chain up a full length tree......"
   / Top 10 things NOT to do with a new loader! #104
Thanks.....Casey
So a old door tied to clamp on forks on the FEL is not a good diving platform for the deep end of the pond?
   / Top 10 things NOT to do with a new loader! #105
Originally Posted by Atlas
...JUMP FROM THE TRACTOR!
Nope. Don't do it! High voltage electricity will arc right through you. Stay Calm. Stay in the Seat. It may be the longest wait of your life, but wait for the power company to de-energize the lines and then get off the tractor.
If the voltage is high enough to arc that far wouldn't it be arcing to ground from the implement or across the wheels to ground? IF it were the really high voltage transmission lines there would be lots of "fireworks" and no doubt about "hot" wires.
The reason JUMP was mentioned rather than step off the tractor was to avoid bridging the operator's body across the voltage, i.e. one foot on the tractor (which may be in contact with a live wire) and the other in contact with the ground (dirt) which is a likely way to get you fried.
It is unlikely that if the operator jumps free and does not come in close proximity to a live wire that there is a high probability of being electrocuted.
If the situation is stable, i.e. the live wires aren't in motion and you haven't been shocked yet it may be safe to just sit there but if you aren't in danger just sitting there why not just slowly drive away from the dangerous area if you can do so without having a live wire touch the operator?
It should be safe (for the operator) for a live wire to touch the tractor so long as it does not directly touch the operator AND if the operator dismounts (s)he jumps down such that the tractor and ground are not touched at the same time.
In any life threatening situation it is incumbent on the participant(s) to tailor their actions to the extant circumstances and NOT apply any suggestions by rote. Err on the side of caution.
Pat
   / Top 10 things NOT to do with a new loader! #106
...If the voltage is high enough to arc that far wouldn't it be arcing to ground from the implement or across the wheels to ground? IF it were the really high voltage transmission lines there would be lots of "fireworks" and no doubt about "hot" wires...
Pat
I can't answer the questions as to how a downed power line would behave. I can tell you that we've lost at least one kid in this area to the false notion that you're safe if you jump. He worked for a friend of mine who is now the maintenance manager here where I work. He jumped from the fender of a tractor and it melted his shoes to the fender. He was into a higher voltage power line feeding irrigation pivots.
I'm not postulating or hypothesizing here about what should be okay or what I think the right answer is. I'm sharing a true life example. Any literature I've ever seen also advises "Stay calm, Stay in the Seat". Also as a 911 rescuer, I've been trained to keep the victim in the vehicle until the power company cuts power and verifies that the line is dead. No one jumps out. No one comes close.
I'm no safety monger, and I take risks. You can check my posting history to verify that. I take those risks knowing the consequences. I think readers here need to know that there is a chance of serious harm if they chose to jump from a vehicle in contact with power lines.
   / Top 10 things NOT to do with a new loader! #107
I repeat the last paragraph of my previous post for emphasis...
Pat
   / Top 10 things NOT to do with a new loader! #108
Oh man, watch out for a surprise manhole when pushing snow. Holy cow, I just about broke both thumbs and still smashed my head into the windshield even with my seatbelt on! :( I still can't believe I didn't demolish my FEL hitting something that hard and stopping about 12,000 pounds from about 6 mph to 0 in about 1 inch (moved the entire manhole about an inch). It stopped so fast my windshield wiper flipped straight out and one headlight popped out of it's socket. I'm still claiming that it was the hard yank by my seatbelt that caused the mess in my pants. Yeah, that's my story and I'm sticking to it! :D
When my dad became supervisor of highways he outfitted all the snowplows w/ 2" thick live rubber blades. His newest equipment operator, graduated from truck driver, wore 'coke bottle' eyeglasses and his first snowstorm in the roadgrader he hooked a manhole while standing up [prefered way to operate a grader so you can see the blade] and broke his glasses.
Dad had the only Cat 112 grader w/ a live rubber cutting edge after that...
Those edges cut his plow repair bills by 2/3rds...
   / Top 10 things NOT to do with a new loader! #109
When using the FEL, don't run the tractor in high throttle because you are in a hurry. The controls move very fast! Use only the necessary throttle speed for the job. And slow down and enjoy the seat time. I've caught myself in a hurry for no reason and have made many mistakes. Thankfully, none to serious.
   / Top 10 things NOT to do with a new loader! #110
I have to agree. the other day I found I barely throttled up more than an idle . I know people saw full throttle then engine will thank you but ill take my chances...I always have my hand ready to lower it just in case..And I find there are allot of times like that
KUBOTA M7-132 (A53084)
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
2018 MACK CHU613 PINNACLE DAY CAB (A53843)
2018 MACK CHU613...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
1263 (A50490)
1263 (A50490)
MASSAGE CHAIR (A53843)
