Towing trailer with Backhoe?
   / Towing trailer with Backhoe? #1
kubotal3130
I have a dump trailer that I like to pull with my tractor but would like to use my backhoe to fill the trailer. Maybe this is obvious to most, but how can I keep my backhoe on and still be able to pull the trailer. Pull it from my FEL backwards or rig something up on my backhoe to accept a ball? I have a Kubota 3130 with a 9' Woods Backhoe Thanks
   / Towing trailer with Backhoe? #2
I mount a ball in the bucket of my B7100 if I want to move a trailer when I have my backhoe on.
   / Towing trailer with Backhoe? #3
I use my front mounted quick hitch with a "three-point" trailer hitch, or a front-mounted carryall (that also has a receiver on it) to pull a trailer when I have something else on the back. This may not be the best if you have a long way to go...
Thanks for the help!
   / Towing trailer with Backhoe? #5
I stuck a receiver onto my hoe bucket linkage and use it all the time. Great for backing a trailer into a tight space as I just swing the hoe a bit (or a lot) to line things up.
I had to get creative and made a drawbar with a "droop" in it so nothing would hit when I tilted the hoe bucket. It also serves to hook under the tongue of my float and allows me to lift and hook it onto the trailer ball without a lot of truck jockeying...
I don't know if I would want to tow a loaded dump trailer with it (none of my land is flat) as there is a LOT of leverage when the bucket is five feet behind my little tractor....
   / Towing trailer with Backhoe? #6
Got pictures?
   / Towing trailer with Backhoe? #7
And you don't have to drive backwards!!
JB
   / Towing trailer with Backhoe? #8
Never have figured out this picture posting, but my hoe (JD47?) has a link that curls the bucket. I built it up a bit with 3" channel and added a 2.5x2.5 tube to the top. I then made a special "draw bar" that had a bend in it to allow it to clear the frame of the hoe when I "dumped" the bucket.
To use it I curl the bucket which leaves the ball sticking out to the rear....
   / Towing trailer with Backhoe? #9
Ah, that makes sense. It doesn't drag the back wall when digging?
   / Towing trailer with Backhoe? #10
The reciever lays flat to the top link and I have a bracket on my ROPS where I store the drawbar. My jacket then hangs on the ball to cushion it from my head. LOL
   / Towing trailer with Backhoe? #11
I've not been around small hoes at all, you have to remove the normal drawbar to mount them right?
   / Towing trailer with Backhoe? #12
On my JD I have to remove my 3pth linkage, a two minute job once the implement/counterweights are off. On my BIL's Massey the arms just swing out of the way...
UNUSED FUTURE FT50-(50) 12' PIECES OF GALVALUME (A60432)
UNUSED FUTURE...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2016 VOLVO SD75B SMOOTH DRUM ROLLER (A60429)
2016 VOLVO SD75B...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2018 FREIGHTLINER...
Cushman Hauler 1200X Golf Cart (A57148)
Cushman Hauler...
2007 Frienghtliner B2 School Bus (A59230)
2007 Frienghtliner...
