Towing with a Ball and Drawbar
   / Towing with a Ball and Drawbar #1
8N_John
Kearney, Missouri
1952 Ford 8N
I will be connecting a ball to my drawbar for towing a small trailer with my 8N. I realize the drawbar will tilt slightly without something to stop it from rotating. However it seems that the rotation would be limited as once the ball is connected to the trailer, the connection would limit the movement.
Is it possible to use this setup without a special device to prevent rotation of the drawbar? Anyone had experience with this?
   / Towing with a Ball and Drawbar #2
Hi John. It would be best if you stabilized the drawbar. Having the pulling and downforce on the hitching mechanism would be looking for problems.
   / Towing with a Ball and Drawbar #3
John, I'm quite confident that the stress of doing it that way will damage the trailer hitch coupler. You can buy a drawbar lock for that purpose from several places.
   / Towing with a Ball and Drawbar #4
Bird, here's the drawbar stay and some details of the mounting that show how it should be attached with the lift arm stays also attached. The slot in the drawbar stay fits around the lift arm stay (see attachment). /forums/images/graemlins/cool.gif
   / Towing with a Ball and Drawbar #5
Yeah, that's better, Jim. I just looked up the first picture I found and yours is a much better picture.
   / Towing with a Ball and Drawbar #6
Another possibility is the EZ mover advertized here. Bolts to your drawbar and uses a top link. Put a receiver hitch in it.
   / Towing with a Ball and Drawbar #7
watch out for shifting loads, aft of the trailer axle. without any bars to the top link, the load can shift and you will have a dump trailer.
   / Towing with a Ball and Drawbar #8
You are asking for trouble in 2 ways.
1, the drawbar can rotate enough to rip a ball out of a cheap/older hitch.
2, the 3pt arms can float up when you try to stop making some weird geometry.
You can get drawbar stays to keep your 11 hole drawbar down, and drawbar locks are easy to make to keep the drawbar from rotating. I've made 2 from scrap metal and a few minutes of welding.
If you have the under fiffy drawbar bracket, you can use the generic TSC drawbar with yor 11 hole drawbar, with a few bits of hardware for support.
To give you an idea of just how cheap/easy it is to make a 'junkyard-scratch built drawbar lock, her eis a pic of one I buzzed together using a piece of rebar, and two scraps of steel I-Beam, and a 'D' bolt, and a regular nut and bolt.. Took 5 minutes to make.. The one ibeam section 'd' bolts around the lift arm, and the other ibeam section has a bolt welded to it that goes thru the 11 hole drawbar, then gets a washer and nut. Takes 1 minutes to install. This one pulled my 16' trailer on a hay ride last year. This year I made a nicer one out of some 1/4 flat stock. and washers/ears/tabs.
Soundguy
   / Towing with a Ball and Drawbar #9
One more thing I'll add. By having a stabilized drawbar that doesn't spin.. you can really get good at moving trailers in your yard without getting of fthe tractor. Just back up, line up the ball, lift the 3pt, and the fixed ball lifts the hitch.. move the trailer where you want it.. drop the 3pt, and leave the trailer there.
Soundguy
   / Towing with a Ball and Drawbar #10
</font><font color="blue" class="small">( I will be connecting a ball to my drawbar for towing a small trailer with my 8N. I realize the drawbar will tilt slightly without something to stop it from rotating. However it seems that the rotation would be limited as once the ball is connected to the trailer, the connection would limit the movement.
Is it possible to use this setup without a special device to prevent rotation of the drawbar? Anyone had experience with this? )</font>
Before I bought my Kioti, I moved a small trailer numerous times that way without a problem. It was on a Massey 65 with a single axle trailer. It is definitely not the "ideal" setup, but it did the job.
I wouldn't go down the road with it!! /forums/images/graemlins/shocked.gif
RedDog
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
2018 Allmand Light tower (A49461)
2018 Allmand Light...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
Honda Pioneer 1000 UTV (A50860)
Honda Pioneer 1000...
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
2019 HONDA PIONEER 5 1000 UTV (A50459)
2019 HONDA PIONEER...
